Controlla i tuoi messaggi privati...Originally Posted by jaba
Check yours private messages...
Well, extract all files with Winrar, copy the BMW E36 directory to the skins directory under RoadRunner then open the directory named "Fonts to be installed" and copy the two files in "C:\WINDOWS\Fonts".Originally Posted by CBDZ
There is also a directory named "FreeDrive", if you use this program as GPS navigator, you must copy the file "sdk.ini" in your FreeDrive installation directory.
Good luck!
Not sure if it is possible, but try this:Originally Posted by Griff1
Create your sub menu with all the buttons you need then put on each button a comand like:
"EXIT||LOAD;<your screen>.skin||SHOWMISSEDCALLS"
where <your screen> is the name of the screen you want to load to show the selected info.
Don't forget to put a P area in the screen you load to show the call list.
Let me know if it works...
Does this skin include XM or will I have to modify it? Im at work or Id test it unstead of asking. Sorry for acting like a noob.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Ottima versione....anche se non ho capito bene la parte del mixer...???
Solo un appunto (per altro già fatto): potresti nelle prossime versioni mettere il logo modificabile??? io ho una ford e il logo BMW non sta tanto bene (ho dovuto cancellarlo sulle 3 parti con psp.....).
Ciao e di nuovo ottimo lavoro!!!!!!!
Alex
I'm sorry but in Europe the SAT radio isn't available so no XM support in this skin.Originally Posted by n8scstm
Ho incluso i sorgenti in PSD esattamente per questo motivo, chiunque voglia personalizzare la skin (cambio del logo incluso) è libero di farlo.Originally Posted by Alx0363
I've included the PSD sources exactly for this reason, anyone that wants to customize the skin (including the change of the logo) is free to make it.
Unfortunately,it didn't work Robby.Originally Posted by Robby BMW
I also wanted to ask you if there is anything special i need to add to get the SMSRECEIVED icon to work?
But i'm guessing its phone support based.
In fact it does work but if you have no missed calls you can't tell.
How does Phoco get its calls info?,is there anyway to get RR or Phoco to store the last 20 MISSED,20 RECIEVED and so on.
At the moment it seems either RR or Phoco dumps the info between restarts,it would be nice to if you could stop that from happening.
There is another thing bugging me and its that you can only display the contacts number in ContactDetails.skin,
Is there any way you could change that? I'd like to be able to scroll down the contacts list and display each contacts number at the same time (1 name and its number,scroll down to next name and its number and so on)
