Page 5 of 23 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 229
Thread: Skin Release: BMW E36
  1. #41
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i agree on the contact screen issue. It should switch to a phone number when the name is highlighted.
    Live mp3Car Facebook Chat
  2. #42
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Not sure about switching.i was hoping to display the name in 1 box and the number in another but yeah switching would be cool aswell
  3. #43
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Nice!
    You got a good OEM look to the buttons too.
    Can you share the PSD's so we can change the highlight colours?
  4. #44
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by Griff1
    Unfortunately,it didn't work Robby.
    Sorry, I have forgotten to tell you that the screens on which is posible to show the calls list can be only "phoco.skin" or "calls.skin".
  5. #45
    Aug 2005
    Italy
    I also wanted to ask you if there is anything special i need to add to get the SMSRECEIVED icon to work?
    But i'm guessing its phone support based.
    Nothing special, you can place the "SMS_ARRIVED_PHOCO" indicator on whichever screen.
  6. #46
    Aug 2005
    Italy
    In fact it does work but if you have no missed calls you can't tell.
    How does Phoco get its calls info?,is there anyway to get RR or Phoco to store the last 20 MISSED,20 RECIEVED and so on.
    At the moment it seems either RR or Phoco dumps the info between restarts,it would be nice to if you could stop that from happening.)
    RR get all the calls list (missed, recived, sent) from the phone through PhoCo every time it is started and it stores the list in a file.
    There are some options in RRconfig, under the phone section, like "Store up to xx numbers in the call lists" and "Phone lists path", that allow to handle this.
    There is another thing bugging me and its that you can only display the contacts number in ContactDetails.skin,
    Is there any way you could change that? I'd like to be able to scroll down the contacts list and display each contacts number at the same time (1 name and its number,scroll down to next name and its number and so on)
    Sure, you can add these five labels in your "contacts.skin":
    "NUMBER_MOBIL_PHOCO"
    "NUMBER_HOME_PHOCO"
    "NUMBER_WORK_PHOCO"
    "NUMBER_FAX_PHOCO"
    "NUMBER_OTHER_PHOCO"
    so, when you scroll up and down your contacts list, all the contact's numbers will be shown.
  7. #47
    Aug 2005
    Italy
    Quote Originally Posted by ShawJohn
    Nice!
    Look at the 1# post... there is a link to the PSD sources too.
  8. #48
    Nov 2005
    Midlands
    Thanks for the Info Robby,its a big help mate.
  9. #49
    Jun 2003
    Memphis - TN
    On the capture skin. Does this embed? Mine doesnt seem to...
    For those needing XM...
    I created a new Skin file that allows me to choose radio or XM , much like the popup for choosing a GPS program, and linked it to the radio button the the menu skin. I copied the XM files and a renamed slider folder from the original brushed metal skin to this skins directory, and changed the slider link the Xm skin. I use the new radio pop-up skin and linked them to the radio skin and the XM skin. Worked like a champ. Keep in mind im @ work so no XM is connected to this machine.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  10. #50
    Aug 2005
    Italy
    Quote Originally Posted by Custommx3
    Edit the "ExecTBL.ini" file in the skin directory (not the one in rr directory) and check if you need to change something on the line
    "CAMERA","LOAD;CAPTURE.skin;;C:\Programs file\Capture!\Capture!.exe;Capture!"
    in order to get it embedded, then edit the file "config.ini" in the Capture! instalation directory and set the option "WindowStateOnLoad" to "CES" and the option "HideButtons" to "1".
    Remember! don't change the default key shortcut in Capture! configuration.
    Let me know...
  1. Kuo Skin Release
    By kuo in forum RR Skins
    Last Post: 12-04-2008, 03:46 PM
  2. (AUS) BMW E36 Extensive Customisation
    By CAA in forum Show off your project
    Last Post: 06-13-2008, 04:44 PM
  3. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  4. 1992 BMW 318IS (E36) Carputer
    By Digital318is in forum Show off your project
    Last Post: 03-09-2007, 08:42 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
