For default RR shown all the menu/popup skins in the middle of the screen, I'm not sure if is possible to change this feature.Originally Posted by Ti-ejtsch
I've tested the skin with MilkDrop without problemas.Originally Posted by tbird2340
first - great skin. even better psds.
I really dont have the time to write my own skin - but I do have the time to modify one to my needs and your skin had the basics I needed and the PSDs were easy to use and modify.
Now for the question.
I had the skin working perfectly then I tried modifying my startup services and seem to have screwed up the online detection icon. Do you kow whih Microsoft service this is going off of?
Does anyone know how to get the video into full screen? I see the video but I can make the controls and the progress bar go into hide mode. Am I missing something??
Project: 1998 BMW 323IC
Installation: Never done
VIA EPIA MII12000/1ghz Ram/7" lilli/M1-ATX/Leadtek BT GPS/Cisco 350 G PC Card/
niccard007 this was a problem for me to. Adding "transition=0" line to rr.ini solved my problem and make sure you set rrconfig video to auto hide.
Will try that out and let you know. Thanks!Originally Posted by pancakeboy
Robby or anyone,
Can someone explain to me how to add an app to the e36 skin or point me in the right direction? I read the FAQ's for roadrunner, but I am just confused. I am trying to add CDR's filemanager 'Freedom' skin beta progress (Flash Based) to the e36 skin as an app and just can't figure it out.
Worked like a charm, thank you very much.
Does this skin supports HQCT?
Hi Robby,
maybe this is an old question but I've not found any info about it: are there some specifications for pictures used to show callers? I've read only something about naming the .jpg file but what about the size ? Is it portrait, landscape or simply squared ? Which is the best image dimension (pxl by pxl) ?
thanks for your work, lucianop
