Page 26 of 35 FirstFirst ... 1617181920212223242526272829303132333435 LastLast
Results 251 to 260 of 342
Thread: iDrive 2.20 Release
  1. #251
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    (if I ever get time)
    theres never enough time, we need an extra day in the week to keep on top of it all!
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #252
    Nov 2006
    Wales, UK
    When i make the switch to PcNavigator, can you suggest a way I can still use your version of FreeDrive so that I still get the speed camera warnings?
    CarPuter Progress:
  3. #253
  4. #254
    Nov 2006
    Wales, UK
    Well if you use a GPSport splitter then just have freedrive running in the background.
    or use GatsoHunter.
    Your FD seems to have the same functionality, seen as with PcNav you only get gatsos not the rest like the red light cameras etc.
    il keep an eye on this http://www.mp3car.com/vbulletin/rr-p...ohunterrr.html
    cheers
    CarPuter Progress:
  5. #255
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Excellent work Enforcer! Any chance we'll see an iGuidance reshack to match the skin?
  6. #256
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not sure at the moment, lots of things to do and not enough time. One of these days I will take a more detailed look at IG stuff, but seeing as we don't use it over here it's difficult to test.
  7. #257
    Aug 2007
    Subaru Logo
    Enforcer,
    Earlier in this thread you posted a Subaru logo in the iDrive skin. The link no longer works, do you have a link that is active by any chance?
    Thanks in advance,
    Ryan
  8. #258
  9. #259
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Ok I lnow it's been a while since I promised you this but hey, better late then never... I guess...?
    These are the changes I made to the iGuidance skin.
    [IMG][/IMG]
    [IMG][/IMG]
    Here is the iGuidance part of the external GPS skin file for the day skin.
    /[GPS=iGuidance]
    L,030,060,150,020,#Fore#,18,"Tahoma:B","=Menu",""
    L,030,110,150,020,#Fore#,18,"Tahoma:B","=Exit iG",""
    L,030,160,150,020,#Fore#,18,"Tahoma:B","=- Zoom +",""
    L,030,210,150,020,#Fore#,18,"Tahoma:B","=Address", ""
    L,030,260,150,020,#Fore#,18,"Tahoma:B","=History", ""
    L,030,310,150,020,#Fore#,18,"Tahoma:B","=Screen"," "
    L,030,360,150,020,#Fore#,18,"Tahoma:B","=Favorites ",""
    L,030,410,150,020,#Fore#,18,"Tahoma:B","=Views",""
    L,030,460,150,020,#Fore#,18,"Tahoma:B","=Full Screen",""
    B,000,050,200,050,"SENDKEY;{ENTER}",""
    B,000,100,200,050,"SENDKEY;%{f4}||GETFOCUS"
    B,000,150,100,050,"SENDKEY;{DOWN}||GETFOCUS"
    B,100,150,100,050,"SENDKEY;{UP}||GETFOCUS"
    B,000,200,200,050,"SENDKEY;{ENTER}{ENTER}{ENTER}{D OWN}{ENTER}||GETFOCUS","Address"
    B,000,250,200,050,"SENDKEY;{ENTER}{ENTER}{DOWN}{DO WN}{DOWN}{DOWN}{DOWN}{ENTER}||GETFOCUS",
    B,000,300,200,050,"SENDKEY;{ENTER}{DOWN}{RIGHT}{EN TER}{UP}{UP}{UP}{UP}{UP}{RIGHT}{ENTER}{LEFT}{DOWN} {DOWN}{DOWN}{DOWN}{DOWN}{ENTER}||GETFOCUS","
    B,000,350,200,050,"SENDKEY;{ENTER}{ENTER}{DOWN}{DO WN}{DOWN}{DOWN}{ENTER}||GETFOCUS",
    B,000,400,200,050,"SENDKEY; {3}||GETFOCUS","Toggle 3D View"
    B,000,450,200,050,"LOAD;gps-full.skin;iGPS;$gpspath$;iGuidance"
    /[/iGuidance]
    And this one is for the Night skin. They are pretty much the same except for the "screen" command. I use it fo changing between day and night. Actually when in day skin, if you press this button iGuidance goes day also. When pressing this button in night skin, i Guidance goes night. So you can't toggle between them but I see no use for that. It works very well like this.
    /[GPS=iGuidance]
    B,000,300,200,050,"SENDKEY;{ENTER}{DOWN}{RIGHT}{EN TER}{UP}{UP}{UP}{UP}{UP}{RIGHT}{RIGHT}{ENTER}{LEFT }{LEFT}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{ENTER}||GETF OCUS",
    B,000,350,200,50,"SENDKEY;{ENTER}{ENTER}{DOWN}{DOW N}{DOWN}{DOWN}{ENTER}||GETFOCUS",
    B,000,400,200,50,"SENDKEY; {3}||GETFOCUS","Toggle 3D View"
    /[/iGuidance]
    Note that I'm still using the rather old 2.1.2 Europe version since in newer versions like 3, they no longer support Europe maps. It should work in other versions as long as the menu lay out is the same...
    For the zoom button I cheated a bit. The button is actualy split in half. So the left part zooms out and the right part zooms in.
    I wanted to add a cancel button but for some strange reason it won't work.
    the -- ,"SENDKEY;{ESC}||GETFOCUS", -- command will not work. If I press ESC on the keyboard iGuidance responds but when using ESC as a sendkey it does nothing. A shame actually because a cancel button would be convenient.
    Thats it I think. Sorry for the late reply and I hope it's usefull.
    Edit -> Oh yeah, I dont think it matters but this is V2.13. I'm stil using that one in the car but now I've got the code for the iGuidance skin finaly on my desktop I can start to change V2.20 to my personal needs and put that one in the car.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  10. #260
    MAH
    MAH is offline
    Newbie MAH's Avatar
    Feb 2007
    Today is September 07, 2013 or perhaps more precisely 07 Sept 2013
    Today is September 07, 2013 or perhaps more precisely 07 Sept 2013.
    IDrive with RR set to get the date from GPS and date format set to dd/mmm/yyyy
    I guess Iíll be changing to dd/mmm/yy . No urgent need of a fix, but I thought you should know about this nuance.
    <EDIT This switch of day and year is actually from RR, not the skin. I was using the GPStime=true and this changes the system date using the day as the year. Setting USAGPSdate=true or false has no effect.>
    and dd/mmm/yyyy does not fit on the screen properly, Iím not even sure that dd/mmm/yy will.
    This is a great skin thank-you for all of the work you have put into it. Iíve tried a bunch of skins and the only two that I can get to function are iDrive and BMV2.
    If the navigation page could be upgraded to include an option for Street Atlas USA that would make it perfect for me (and anyone else that needs to GPS their way across Mexico) ÖÖand I can probably help with that upgrade.
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. [SKIN]FPs "Bright Life" (input needed to complete)
    By yunusyu in forum FrodoPlayer
    Last Post: 06-25-2005, 03:59 PM
  3. RELEASE - FreeDrive 0.60
    By CdRsKuLL in forum FreeDrive
    Last Post: 06-10-2005, 05:45 PM
  4. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 06:19 PM
