Page 27 of 35 FirstFirst ... 17181920212223242526272829303132333435 LastLast
Results 261 to 270 of 342
Thread: iDrive 2.20 Release
  1. #261
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by MAH View Post
    Today is September 07, 2013 or perhaps more precisely 07 Sept 2013.
    IDrive with RR set to get the date from GPS and date format set to dd/mmm/yyyy
    I guess I’ll be changing to dd/mmm/yy . No urgent need of a fix, but I thought you should know about this nuance.
    and dd/mmm/yyyy does not fit on the screen properly, I’m not even sure that dd/mmm/yy will.
    Not tried this getting date from GPS thing, but I doubt it would be the skin adding 6 years.
    I don't use the above formats for the date, you can see from the screen captures which one I use. If the one you want touse does not fit, try changing the size of the font used for the date.
    It will be in the top.skin and gpstop.skin.
    If the navigation page could be upgraded to include an option for Street Atlas USA that would make it perfect for me (and anyone else that needs to GPS their way across Mexico) ……and I can probably help with that upgrade.
    I don't have a copy of Street Atlas to test However if someone can furnish me with a trial copy or just the key codes to make it do things I can try and add support for it.
  2. #262
    MAH
    MAH is offline
    Newbie MAH's Avatar
    Feb 2007
    Quote Originally Posted by Enforcer View Post
    I can work on the key codes.
    You are correct Idrive is not the source of the date (year and day switched) problem. I did some more digging around and RR appears to have a serious problem with the GPS date (at least here in the US it does).
  3. #263
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    What???!!!! STREET ATLAS into this skin??? I tell you En4cer, you're almost the next picasso in this skin business now that CdR is gone. I've been waiting for this for a looooong time! As far as I know, Street Atlas doesn't use keycodes. I have versions 2003,2004,2005 and 2006, even the DVD version of 2004 with phone numbers. It doesn't matter if there is no fancy zoom, menu or whatever buttons, just having the damn thing embed will suffice for most of us using it!.
    Let me know if you needs anything!
  4. #264
  5. #265
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I now have a 'trial' copy of street atlas
    Had a quick play.
    Now what I need from you is what features you want to be able to control from RR (ie have on the buttons down the side.)
    Teaser screen shot of it embedded in the new iDrive Transparent, ignore the buttons at the side, I haven't changed them from the freedrive version yet.
    Although when you exit RR it gives an application error, so might have to have sendkey command to shut it down first
    Cheers E.
  6. #266
    Jan 2007
    Hispaniola
    Cool, Cool... Since we don't have access to the GPS tab showing the current speed, is there a possibility to add it somewhere to the left and eliminate a couple of labels? As far as I know, SA can not be controlled programatically and the sidebar commands would be useless (unless you found a way to make them interact with the program)
    Cheers.
  7. #267
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Maddominican View Post
    Cheers.
    I can use sendkeys to control SA, you can also set up your own hotkey combinations for some of the features.
  8. #268
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Hi E,
    Im trying to get PCNavigator 7 integrated into your skin, i have it working ok with the GPS set as external on RRconfig, how do i make the 'full screen' button do the same as it does for FreeDrive?
    ive seen the code on external GPS that calls for the gps-full.skin im assuming i just replace the Freedrive parts with the correct window name (In my case Navigator), if this works for me i can upload, and you can intergate support in your next release.
    PS: How do the battery skin go after?
    Cheers.
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  9. #269
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jonessc View Post
    Hi E,
    Yes you should just replace the FreeDrive bits with the navigator bits, ie window name exe etc.
    Cheers.
    Post 5.
    http://www.mp3car.com/vbulletin/rr-s...velopment.html
    Oh and also re your cover browse query
    Browse by Cover (Coverflow) - Updated 11/8/07
  10. #270
    Nov 2006
    Wales, UK
    top job!
    how did you find the speed of the album browser? we seem to have the same spec carputers by the look of it...
    CarPuter Progress:
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. [SKIN]FPs "Bright Life" (input needed to complete)
    By yunusyu in forum FrodoPlayer
    Last Post: 06-25-2005, 03:59 PM
  3. RELEASE - FreeDrive 0.60
    By CdRsKuLL in forum FreeDrive
    Last Post: 06-10-2005, 05:45 PM
  4. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 06:19 PM
