in that case ill try it, and let you know...
Not tried it in the car, I only tested on the PC at work, and only briefly to check my XML creation program worked.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
have you made your own skin for this? wot code did you put on the button to load cover browser?
cheers e
CarPuter Progress:
I added
"COVERFLOW","LOAD;coverflow.skin"
to ExecTBL.ini in the skin folder
Then the button code is
B,000,150,200,050,"COVERFLOW",""
then the coverflow.skin
Code:MEDIACAR Skin MEDIACAR idrive "Skin Browser" skin picviewer_empty.png,base_off.png,base_on.png,base_on.png [Top info bar] INC,top.skin [/Top] [Side Buttons] L,030,060,150,020,#Fore#,18,"Tahoma:B","=Select","" L,030,110,150,020,#Fore#,18,"Tahoma:B","=Prev","" L,030,410,150,020,#Fore#,18,"Tahoma:B","=Next","" /L,030,460,150,020,#Fore#,18,"Tahoma:B","=Full Screen","" B,000,050,200,050,"CLEARLIST||!SELECT", B,000,100,200,050,"PGUP","" B,000,400,200,050,"PGDOWN","" B,000,500,200,050,"EXIT","" [/Side] [Window] /, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name S,10,162,190,230,255,255,255,16,107,245,209,209,209,255,255,255,255,255,255,47,114,187,true,16,"GE Drover:B" SD,00,1,25,25,"$musicpath$","$audiofiles$",false, F,200,42,600,516,"coverflow\coverflow.swf" [/window] [Bottom info Bar] INC,bottom.skin [/Bottom] END
You will need to change the .png files for .jpg versions in the curent sins.
I apologize for my delayed input on this subject. I've been away, my laptop crashed and I was driving my older Mexitruck ( no carputer).
I would like the following included
Zoom +
Zoom-
Full Screen
Address (destination)
Set current GPS start as start
Favorites (or open file?)
Show turns / show list (toggle)*
Perhaps I would like these, but I could be talked out of any of them
High Contrast (on / off toggle)
Insert via
Increase height of lower split screen window
Decrease height of lower split screen window
I have used descriptions rather than short names for the buttons
*to see this toggle you have to enable gps and then look at the route tab (this will prob work even without gps connected, as it does for me).
Obviously practical programming limits over rule my wish list
…and I’m not married to this list and so suggestions for changes are welcomed.
CarPuter Progress:
I think I added to the Audio Player, instead of having Album Browser.
CarPuter Progress:
Enforcer,
Did you ever get your hands on some good photos of the latest verion of iDrive to update the look of your skin? A good friend of mine just bought a new 335i with navigation/iDrive. I am sure I could get pictures of all the screens to help you with your development.
