Page 6 of 35 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 342
Thread: iDrive 2.20 Release
  1. #51
    May 2005
    Germany
    Hi,
    would it be possible to switch between GPS.skin and power-dvd.skin? For now I have a problem because when I switch from dvd to gps, powerdvd always stops and I have to start it again.
    Ti-ejtsch
  2. #52
  3. #53
    May 2005
    Germany
    I have found it:
    write in rr.ini -> usedualmon=true and it will work.
    Ti-ejtsch
  4. #54
  5. #55
    Nov 2006
    Russia
    Quote Originally Posted by Enforcer View Post
    Theorectically if you choose Road Runner you don't have a GPS program loaded and therefore don't need a button to transfer to it. Guess you might still want the logo though. Will change that.
    As you have a 'None' GPS option, 'RoadRunner' seems to me 'other than listed' in config.
    That's how those buttons work in the video screen. AFAIK
    Maybe change them to NEXTTRACK/PREVTRACK for this screen is a good idea? Seeking can be done using slider.
    Which navi are you using?
    I'm using russian navi program, because others has no maps for my country.
    I have changed sattelite icon on the navi screen to launch an OSK.
    That's by design, to get out of that screen press the BMW logo which takes you back to main menu. If that's covered as well then you haven't got the right window name of the app in the apps ini
    Yes, I can use BMW logo to exit to main menu, but how can I launch an OSK or close application? I've added a few buttons to the low bar on this screen (see picture). I think it's a good idea.
    Have you any plans to change size of the low bar?
  6. #56
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by glouck View Post
    The Road Runner option was put in for uses which have a GPS receiver connected to allow the Speed and number of sats displayed through RR
    maybe.
    There won't be any support in the skin for that, so you will have to make up the buttons yourself, so the buttons down the side can be whatever you want.
    Haven't really done much with the launch screen, it's very much as BTBE orginally designed it. might have a look into it for future releases
    Not for the main releases, might at some time in the future release a different variation with bigger top and bottom headers.
  7. #57
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Cool
    Can't wait to try it out! Been waiting for this for a while now.... on my phone, but I will definitely try it out tomorrow. Big thanks as always Enforcer!
  8. #58
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    5. Some symbols do not work in OSK: ; ! % ^ ( ) + ~
    Right done some checking,
    the following work for me
    These don't work
    I think these are special characters in skin codes, will see if there is a way around this.
  9. #59
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Here are a list of problems, that I found:
    1. Deselecting phoco in config removes all sliders (mixer, eq, audio, video)
    2. If I select select 'RoadRunner' GPS in config, the sattelite icon disappears from all screens
    6. On the launch screen there is no selection highlight
    7. Any open application on the launch screen overlaps all buttos on this screen
    Ok after doing a bit of testing I have made some changes.
    download the following files and extract them to your iDrive folder, these will overwrite the top.skin, gpstop.skin, cdrip.skin and launch.skin and will correct the slider problem and the 'missing' satelite symbol if RoadRunner is selected. Also they correct the no selection and applications covering up the buttons in the application/launch screen.
    There is one manual adjustment to be made and that is to rename the slider folder
    slider_PHOCO_signal
    to
    slider_phone_signal
    a Similar correction post has been made for the Night version too, and that file is in the night skin thread.
    http://www.mp3car.com/vbulletin/show...694#post967694
    Cheers E.
    Attached Files Attached Files
  10. #60
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by MycoDeX View Post
    how about we make a deal enforcer?
    a logo for a chrysler in exchange for iG3
    e-mail me at shadowmpg(at)hotmail.com
    I have a choice of two, which do you want?
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. [SKIN]FPs "Bright Life" (input needed to complete)
    By yunusyu in forum FrodoPlayer
    Last Post: 06-25-2005, 03:59 PM
  3. RELEASE - FreeDrive 0.60
    By CdRsKuLL in forum FreeDrive
    Last Post: 06-10-2005, 05:45 PM
  4. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 06:19 PM
