Results 1 to 6 of 6
Thread: Renovatio Skin - Pre-Release V2.2
    Aug 2007
    Roma
    Hello Guys,
    I need your help to understand some things ...
    channel list in the first screen, is no longer defined as all other .. This happens only in FM radio, the lists are equal in all file.skin.
    As you can see the definition of the characters in the list in FM radio is the only defined in relation to all other label.. why ? :-(
    The following is the code:
    RADIO FM
    S,158,98,335,415,255,255,255,0,0,0,255,255,255,0,0 ,0,244,181,8,,20,"GE Drover"
    AUDIO PLAYER and other list :
    S,150,86,343,430,255,255,255,255,0,0,255,0,0,255,0 ,0,255,0,0,,18,"GE Drover"
    The only difference is the size, the first is set to 20 and the second 18, but I also tried to change the values but I see them hurt. grrrrrrrrrrrrr...
    Another question, how do I eliminate this horrible pink pig? :-)
    code:
    S01,506,103,167,398,255,255,255,255,255,255,255,25 5,255,255,255,255,255,255,255,241,181,8,TRUE,14,"G E Drover"
    SD,00,03,30,30,"$picspath$","*.jpg;*.bmp;*.gif;*.p ng",FALSE
    IL01,DL,transparent.bmp,sel.bmp,1,70,50
    code:
    IL,CL,transparent.bmp,sel.bmp,end.bmp,0,50,60
    SC,150,85,339,430,255,255,255,0,0,0,0,0,0,255,0,0, ,18,"GE Drover"
    thanks...
    Riko
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    What I do is make the transparent.bmp 800x600 in size. Nice lookin skin BTW!
    Aug 2007
    Roma
    Hi,
    I changed the color of the Sel.BMP to black and now is ok ...
    mmmmmmmmm
    why ?
    MySQL Error
    Oct 2004
    well...
    Bitmap Mode Transparency: PAR1=TRANSPARENT.BMP -- File MUST exist, but its contents are ignored.
    IL,DL,transparent.bmp,sel.bmp,end.bmp,0,20,70
    NOTE2:
    When using Bitmap Transparency, PAR2 and ENDBMP (Sel.bmp and end.bmp in the example) can have transparent areas
    by simply making areas with the RGB color FF00FF (Full Pink) -- You MUST however is to make sure the size of
    the BMP file is AT LEAST THE SIZE IT WILL BE DISPLAYED -- otherwise, you may loose the transparency effect
    due to stretching of the pixels when loading the image.
    not sure if that helps
    one thing for sure bmp files dont support transparancy, and black is used for transpancy in some things in RR
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    that is one badass looking skin!
    Live mp3Car Facebook Chat
    Aug 2007
    Roma
    Yes understand ....
    thanks Guys ...
  1. Fullscreen Winamp5 skin beta release
    By Arby in forum Software & Software Development
    Last Post: 12-05-2010, 11:42 PM
  2. Renovatio, my First skin .... :-)
    By riko in forum RR Skins in Progress
    Last Post: 07-25-2009, 03:36 PM
  3. New flash skin...new Video 03/13/09
    By pcpete in forum RR Skins
    Last Post: 03-17-2009, 01:15 AM
  4. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  5. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
