Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 82
Thread: Shock Version 7
  1. #21
    MySQL Error
    Oct 2004
    I DONT SEE any problem at all, its working fine...
    you do have it set to use external audio capture...
    (not to mention, you didnt actaully do any commands that would do anything to the tuner...
    like freq+)
    you dont need a playlist
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is an interesting issue... I would like you to try TeamRSX suggestion and report back.
    I also would like you to try (without the TeamRSX's suggestion) using the "TUNE" command after you go into the radio screen -- maybe that will trigger the radio ... if so, I can see that we'll need to add a small fix to the radio modules so that they tune to the last used frequency when there's no playlist.
    Ride Runner RR's Myspace
  3. #23
    MySQL Error
    Oct 2004
    no playlist needed, it tunes from radio.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #24
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by TeamRSX View Post
    I remember i had the same problem with my HD radio not activating when going to the Radio_Player.skin.
    I think all i did was put a playlist object in the skin file, but i can't be 100% sure. Looking back i had the following code at the end of my 'Indicators' section in the radio_player.skin file.
    S01,798,0,2,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,TRUE," 12","Arial"
    Give it a shot.
    I think this is correct, I remember back having this problem in coding before. I think RR needs to see the 'S' code in order to fully initialize the radio skin. Ill give it a try.
    Thx guys.
    Edit:
    This worked thanks for the reminder RSX.
    Guino, Ill try the tune command with and without the S code.
  5. #25
    Jul 2005
    Motorcity
    Blog Entries
    1
    Ok so everything is working good, but it looks like ill have to package some fonts with it. RR always defaults to comic sans when it can't find a font lol.
  6. #26
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Blk - is the button text part of the (button) graphic, or are they labels?
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  7. #27
    Jul 2005
    Motorcity
    Blog Entries
    1
    they are part of the artwork
  8. #28
    Jul 2005
    Motorcity
    Blog Entries
    1
    I have noticed art is quicker rendering than label overlays.
  9. #29
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by blk02si View Post
    Thx guys.
    Edit:
    Glad you were able to get the radio player skin working. Looking forward to the release. Looks great..
    Also, what GPS program are you using (iGo)? Looks very tough screen friendly. I'v been using iguidance since i'v had the carpc, but have wanted to try something else just to compare.
  10. #30
    Jul 2005
    Motorcity
    Blog Entries
    1
    Yep I am using iG08
    I was using iGuidance 3.0 for a long time, and still do like it but iGO has way better font/map rendering and smooth scrolling.
    This embed is perfect as the iGO app is sized for 800x480 and my application code and clipping code are both set to 800x480. The art is designed to fit it, and I gotta say it works well.
  1. Streetdeck Rollback
    By brombomb in forum StreetDeck
    Last Post: 01-23-2008, 08:28 AM
  2. [FRONTEND] MMC New Release 11.20.2006
    By Bitoholic in forum Mobile Media Center
    Last Post: 05-03-2007, 07:59 PM
  3. VisualDesigner for creating other skins
    By zorro in forum Software & Software Development
    Last Post: 02-17-2007, 09:38 AM
  4. Archive
    Last Post: 09-21-2006, 05:59 PM
  5. Bugs so far in 1.3 BETA
    By GReeToZ in forum Centrafuse
    Last Post: 07-17-2005, 08:00 PM
