Page 10 of 36 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 351
Like Tree8Likes
Thread: eLite | 2
  1. #91
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by yd82 View Post
    Yes, I did change only SHOWHEIGHT to 600 and keep ORIGINALHEIGHT at 480. I tried on 2 computer and did not get any different result. Do I need to check anything else? I change the general.ini in the folder c:\Program Files\Riderunner\Skin\Elite2\general.ini . Is that the correct path?
    Do you have RR in legacy mode or profile mode? If using profile mode, that is the wrong path the path should be %MYDOCUMENTS%\Riderunner\skins\Elite2\general.ini
    note the bold. Unless you typed that path in error your path to general.ini is wrong either way.
    And just a note, if you're not using profile mode i would suggest you do. Mitchjs even has a script available that will make the plugins/skins/etc switch for you automatically. When i reluctantly switched to profile mode i noticed small problems like some of the ones you all are describing went away.
    Live mp3Car Facebook Chat
  2. #92
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by SteUK View Post
    Nice! Fancy sharing it??
    Gimme a day or two to test in the car then i will post it on my skydrive
  3. #93
    Jul 2010
    Thanks Sonicxtacy02, I finally made it work. The reason is that I use function edit general.ini in RRconfig and somehow I cannot save what I change. Going into your path and using notepad to edit.
    When will the next release of Elite 2, I love the skin very much. It will be perfect when RRmedia is intergrated.
    LV.
  4. #94
    Mar 2008
    OK.. Figured out how to replace fonts...
    (Sorry. A CF escapee here. Last time I touched RR was a couple of years ago : )
    Quote Originally Posted by maxthebuilder View Post
    Hello,
    Any chance for Unicode support? None of my titles tagged in Cyrillic show up correctly - I only get empty boxes instead of letters. That would be terrific. Trying to switch from CF to RR. Your skin is the best!
    Thanks,
    --max
  5. #95
    Woodbridge, VA
    Blog Entries
    55
    LV.
    Yea RRMedia i'm missing, especially being about to rate my songs. I'm considering hacking together those skins too as a matter of fact lol.
    EDIT
    Couldnt' help myself, RRMedia is 90% skinned
    I think once this skin gets into final builds alot of people will consider RR again. This is the best skin for a CF convert.
  6. #96
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    It's been almost a month now and I wanted to give an update to the current status of eLite 2:
    Update:10-7-11
    BUGS FOUND:
    - HD Radio Add Preset (fixed)
    - OSK .WWW KEY (fixed)
    - Save Playlist Root button (fixed)
    - Load Playlist Root button (fixed)
    - Audio Cd click on track in list and play (fixed)
    SKIN CHANGES MADE:
    - new main menu
    - new entertainment menus
    - new tools menus
    - new settings menus
    - new shutdown menus
    - updated menu icons
    - new Media List support for Audio
    UPCOMING PLUG-IN SUPPORT:
    - RRMedia (98% Done)
    -.net Bluetooth Mobilephone (90% Done)
    - RRVehicleMaintenance (75% Done)
    - RRTMS - RoadRunner tire monitoring system (90% Done)
    RELEASE TIME FRAME:
    - by the end of the month
    NOTE: SOME OF THE IMAGES BELOW WERE TAKEN BEFORE THE ALPHA RELEASE AND MAY CHANGE AT THE TIME OF RELEASE.
    NEW MAIN
    NEW MENUS
    NEW MENUS USING WHITE ICONS
    RRMEDIA BROWSER
    RRMEDIA BROWSE BY
    RRMEDIA SORT BY
    TIRE PRESSURE MONITORING SYSTEM
  7. #97
    MySQL Error
    Oct 2004
    Very nice!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #98
    Woodbridge, VA
    Blog Entries
    55
    simply incredible
  9. #99
    Aug 2008
    Very nice. It will be nice to have PDC (Park Distance Control) plugin support also.
  10. #100
    May 2006
    Calgary, Alberta
    Oh hell yes! I have 2 questions though, issues I had with the previous version and I'm wondering if they're fixed:
    - The fonts were too big, I could never make out the song name on the audio screen. They were cut off.
    - The videos didn't play full screen, only native resolution. How do I go full screen?
    Otherwise looks awesome, going to try it soon!
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. eLite | Wings (eLite Wings 2 update)
    By suavecito in forum RR Released Skins
    Last Post: 01-31-2016, 03:07 AM
  2. eLite | Streamline preview
    By suavecito in forum RR Skins in Progress
    Last Post: 01-14-2013, 06:39 PM
  3. riderunner help - elite lite
    By Joshc8503 in forum Road Runner
    Last Post: 12-09-2009, 04:07 PM
  4. Elite C7VCM
    By Z0rr0 in forum General Hardware Discussion
    Last Post: 12-17-2007, 06:03 AM
  5. Compaq LTE Elite Modifications
    By cspos in forum General Hardware Discussion
    Last Post: 08-26-2004, 05:05 PM
