Page 22 of 36 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 351
Like Tree8Likes
Thread: eLite | 2
  1. #211
    Feb 2011
    Thanks it's exactly what i needed, i'm adding something like control also memory cards and usb space drives with safe unplug, and fixing little visual bugs
    for example there is the tirth button on the bottom bar (tirth from the left after setup icon) that is active also without any real command so you can click it and nothing happen (i'm going to put there the safe remove of memory and usb)
    and one visual little bug is in setup bar i add you a pic for understand is hard to explain
    But are just little bugs even because this is an alpha
  2. #212
    Newbie Darude's Avatar
    Jan 2012
    Moscow
    Quote Originally Posted by suavecito View Post
    Tag Fix:
    1. Open RRConfig
    2. Under Music, Click on Tags & Formatting
    3. In the ID3 Tags section, Click on the drop down box
    4. Select ID3v1 or ID3v2 or Mix each other
    5. Save and Restart RR
    suavecito
    Thanks for a great work and amazing skin for RR, it is best skin!
    I hope it will be more new versions of it.
    I have similar problem like Diavoletto, but this steps doesn`t take any effect. Also i can see only highlighted line in current playlist. There is 2 mistakes i made:
    User Remote desktop connection to tune pc, and via control pannel i enabled Microsoft Net Framework 3.51 - to work correctlu in my situation it should be disabled. I use Windows 7 x86.
Size:  158.3 KBName:  player.png
  3. #213
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Now what have I done?
    Can anyone tell me what I have done to this poor skin now? It sur eis taking a beating from me
    Notice the bottom of the text cut off. Thanks in advance for any help offered.
    Name:  Font Issues.jpg
  4. #214
    MySQL Error
    Oct 2004
    dont know, but please dont shoot me, i changed the command in RR, "pluginmgr" to "RRPluginMgr" (in next release of RR)
    why, just to bring it to the standard RRxxxxxx for internal RR stuff...
    oh, duh i know why, you dont have the FONTS installed
    go to the font folder, highlight all of em, right clock, INSTALL
    see:
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #215
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thanks Mitch. I didn't remember having to manually install fonts on previous installs but that was the issue. As usual, you nailed it first time!
  6. #216
    MySQL Error
    Oct 2004
    yea.. i dont know what his installer does... but it should install them
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #217
    Jan 2012
    UK
    Quote Originally Posted by Diavoletto View Post
    I've tested it, it's really nice but there are some little bugs:
    - some buttons are bugged when clicking no show the blue layer
    - contacts button doesn't work for me
    - on the istruction you say "copy the 2 skin files and the 2 PNG files into the elite folder" but only one skin file is on the rar, is missing the incoming call skin
    by the way keep up the good work
    Fixed both the Skype & mobilephone skin files, added the extra background image files, and update the instructions as there was only 1 skin file for the mobilephone.zip
    Not sure about the contacts, it's working on my machine I read all the contacts from "C:\Program Files\RideRunner\Plugins\Mobilephone.NET\contact\M obilePhone_PC.txt"
    https://skydrive.live.com/redir.aspx...107&parid=root
  8. #218
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Duplicate post from RRPandora thread.... For anyone using the RRPandora skin there are a few changes that needed to be made to the elite files to get everything working as it should. Most of them boil down to not having a definition for RRPandora's ACTIVESOURCEID of 10.
    1. No Track/Artist info in top bar
    FIX:
    Edit "Top-round.elite" found in eLite 2\elite\static and change:
    Code:
    L,175,2,450,28,255,255,255,16,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<TAGTITLE||= - ||TAGARTIST<<RDSTEXT<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE<<=Video File<<TRACKNAME<<","SCROLL-CENTER",,"DS=1,2,0,0,0"
    L,246,34,305,24,#FONTTHEMER#,#FONTTHEMEG#,#FONTTHEMEB#,14,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGARTIST<<TRACKTIME<<TRACKTIME<<","SCROLL-CENTER",,"DS=1,2,0,0,0"
    to
    Code:
    L,175,2,450,28,255,255,255,16,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<TAGTITLE||= - ||TAGARTIST<<RDSTEXT<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE||= - ||TAGARTIST<<TAGTITLE<<=Video File<<TRACKNAME<< << <<TAGTITLE","SCROLL-CENTER",,"DS=1,2,0,0,0"
    L,246,34,305,24,#FONTTHEMER#,#FONTTHEMEG#,#FONTTHEMEB#,14,"#FONTFAMILY#","BYVAR;ACTIVESOURCEID;=<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<FREQUENCE||= ||FMAM||= - ||RDSNAME<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGTRACKNUMBER||= - ||TAGALBUM<<TAGARTIST<<TRACKTIME<<TRACKTIME<< << <<TAGARTIST","SCROLL-CENTER",,"DS=1,2,0,0,0"
    2. Skip forward and back do not work
    FIX:
    Edit "Static.elite" in eLite 2\elite\static and change:
    Code:
    B,268,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tunedown<<tunedown<<prev<<prev<<prev<<prev<<prev)",@BYVARX;ACTIVESOURCEID;(<<prev<<prev<<prev<<prev<<FRWD<<PREVTRACK<<PREVTRACK)@
    B,356,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tune<<tune<<tune<<tune<<play<<play<<play)",
    B,444,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tuneup<<tuneup<<next<<next<<next<<next<<next)",@BYVARX;ACTIVESOURCEID;(<<next<<next<<next<<next<<FFWD<<NEXTTRACK<<NEXTTRACK)@
    to
    Code:
    B,268,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tunedown<<tunedown<<prev<<prev<<prev<<prev<<prev<< << <<prev)",@BYVARX;ACTIVESOURCEID;(<<prev<<prev<<prev<<prev<<FRWD<<PREVTRACK<<PREVTRACK<< << <<PREVTRACK)@
    B,356,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tune<<tune<<tune<<tune<<play<<play<<play<< << <<play)",
    B,444,420,88,60,"BYVARX;ACTIVESOURCEID;(<<tuneup<<tuneup<<next<<next<<next<<next<<next<< << <<next)",@BYVARX;ACTIVESOURCEID;(<<next<<next<<next<<next<<FFWD<<NEXTTRACK<<NEXTTRACK<< << <<NEXTTRACK)@
    3. No play/pause button
    FIX:
    Duplicate a play_xx.png image in eLite 2\icons\players\controls\ and rename to play_10.png
    After these changes you should see track info in the top pane and all transport controls on the bottom should function as intended.
  9. #219
    Apr 2011
    Quote Originally Posted by jeunefred View Post
    I had this idea, would it be hard to change the screen buttons from a 2x3 to a 3x4 instead. So instead of 6 options and 2 page, you could have 12 options in 1 page. I figure since those 2x3 has lots of room, having more buttons couldn't hurt? This is just a suggestion I don't know how much work could be involved to make that possible...
    Just wondering if this is possible?
  10. #220
    Jan 2012
    Moscow
    Meny 3x4 grid - Just wondering if this is possible?
    Shure it is possible and not so difficult
    1) You need redraw menus.png file
    2) Edit menu1.skin,menu3.skin and menu5.skin - add new buttons (if you want use only 1 menu screen on each button from menu.skin file - you can take $MENUBUTTONLABEL__$ from menu2,4,6.skin files or create new ones in execTBL.ini and other skin files.
    If you want do smth with menu you shoud try, it is a good way) Just add something and look how it`s looks.
    PM if you have troubles with it, i`ll try to help.
  1. eLite | Wings (eLite Wings 2 update)
    By suavecito in forum RR Released Skins
    Last Post: 01-31-2016, 03:07 AM
  2. eLite | Streamline preview
    By suavecito in forum RR Skins in Progress
    Last Post: 01-14-2013, 06:39 PM
  3. riderunner help - elite lite
    By Joshc8503 in forum Road Runner
    Last Post: 12-09-2009, 04:07 PM
  4. Elite C7VCM
    By Z0rr0 in forum General Hardware Discussion
    Last Post: 12-17-2007, 06:03 AM
  5. Compaq LTE Elite Modifications
    By cspos in forum General Hardware Discussion
    Last Post: 08-26-2004, 05:05 PM
