Page 21 of 32 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 315
Like Tree1Likes
Thread: eLite | 2 (alpha) Released 9-15-11
  1. #201
    MySQL Error
    Oct 2004
    philg, 1st use screen capture software(would look better), 2 provide better info, like versions, what dvd player you using, etc
    skipping, youd GMPC issue, cause i dont have that software...but im sure you got something set wrong...
    1. Browser, are you USING MY WEB BROWSER PLUGIN?, its required... you will see on 1st page here, supports "RRWebBrowser"
    2. DVD, my recomendation is for both VIDEO PLAYER and DVD PLAYER, is MEDIA PLAYER CLASSIC - HOME CINEMA!!! (MPC-HC) http://mpc-hc.sourceforge.net/
    all you need technically is the MPC-HC.exe (i install then copy mpc-hc.exe to rr root, so that rr has its own version, run it once)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #202
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thank you Mitch, for the help with this. Once the March RR release is out, (decided to wait for it since I had to update the W8 OS anyways). Once I have it installed, I will follow your directions above and see what works.
    The DVD player is a USB ext Samsung SE-T084.
    Totally missed the browser plugin, I'll get that loaded as well as MPC-HC.
  3. #203
    MySQL Error
    Oct 2004
    philg, thats a DVD drive...has nothing to do with the DVD Player...
    my suggestion is ust MPC-HC for both videos and dvd
    my settings:
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #204
    Jan 2012
    Any ETA on a update for this? would really like to get the phone plugin working
  5. #205
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    @mitchjs, thank you for pointing me in the right direction. I have done a format/install of W8 CP edition with March RR and MPC-HC. Most of my issues are gone. I appreciate your time on this.
  6. #206
    MySQL Error
    Oct 2004
    till he releases update... the audio_playlist_load.skin needs a fix
    B,322,359,156,62,"SELECT||AUDIO",
    to
    Code:
    B,322,359,156,62,"Loadlist;$PlayListPath$$ListText$||AUDIO",
    i didnt play with saving skin, but it prob needs a similar fix
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #207
    Feb 2011
    man this skin is simply the best, never seen better skin in ride runner keep it up!
    i have just a little problem with labels
    can't see music info and also title etc in topbar
    How can fix this?
  8. #208
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Diavoletto View Post
    How can fix this?
    Tag Fix:
    1. Open RRConfig
    2. Under Music, Click on Tags & Formatting
    3. In the ID3 Tags section, Click on the drop down box
    4. Select ID3v1 or ID3v2 or Mix each other
    5. Save and Restart RR
  9. #209
    Feb 2011
    thanks it just fixed the problem
    Have a question, i would make some skin for plugin (for example youtube, mobilephone, skype):
    Under jumpto-search.skin the command for search is (B,714,141,80,69,"SEARCHFILES"), i just need the Search keyboard skin to edit and implement in another skin file so it will be used for search for example videos on youtube plugin / contacts on skype plugin / and so on
  10. #210
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    The search skin is really the OSK.skin, it loads this skin when you click on the SEARCHFILES button. Depending on the plugin skin that you are trying to make, some require you to build a separate OSK skin specific to that plugin. You will need to look under the plugin documentation to see if this is required. Using you can just copy the OSK.skin and make the necessary changes.
  1. FreeFone standalone alpha 1.1 Released
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-06-2010, 07:17 AM
  2. Replies: 16
    Last Post: 12-28-2006, 12:09 PM
