Page 23 of 32 FirstFirst ... 1314151617181920212223242526272829303132 LastLast
Results 221 to 230 of 313
Like Tree1Likes
Thread: eLite | 2 (alpha) Released 9-15-11
  1. #221
    May 2005
    Rochester, NH
    Anybody come up with a rrmedia skin? I started looking at doing it and I'm not sure where to start. I've been trying to understand the demo skin but I'm just not very good at skinning
  2. #222
    Oct 2010
    I downloaded and ran the installers for rrpandora and for elite 2 skin. pandora works in carwing but is not even detected in elite2. What am I doing wrong? What ini files do i need to edit to get to work?
    I found out the plugin menu in elite2 does not work. Any suggestions on how to get the menu to work to load plugins? Everything works fine in carwings.
  3. #223
    May 2005
    Rochester, NH
    Quote Originally Posted by dmcdlrn View Post
    Well, I took another stab at this this morning and made a limited skin (missing cd changer stuff and init screen stuff). Now I have to figure out ilist. I basically took the demo screen and changed the images and location of buttons. Any suggestions
Size:  363.8 KBName:  Capture2.PNG
  4. #224
    Oct 2010
    I was able to get the plugins and pandora skins to load, but pandora just displays it's skin and nothing happens and no music loads.
  5. #225
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Here is something weird,
    I was listening to some tunes today with the Elite2 skin, and when I clicked on the visuals button the visual window turn all transparent white.
    Now no visuals work for any skins, Carwings, DFX.
    I'm using the one from the "Spectrum Analyzers" folder in the DFX skin, that I put in the Winamp --->plugins --->avs folder.
    Always worked fine until I clicked on the vis button.
    Has this happen to anyone else?
    Here is my debug files, after using each skin. If this helps.
    Thanks.
    Attached Files Attached Files
  6. #226
    FLAC WuNgUn's Avatar
    Sep 2007
    How come when I install a plugin, I can't add it to a 'button'...either it doesn't show in the list of available plugins or when I select on (TPMS for example) it doesn't show up?
    I'm a newb with RR BTW
  7. #227
    Newbie Darude's Avatar
    Jan 2012
    Moscow
    Quote Originally Posted by WuNgUn View Post
    Check is it profile installation of RR or Legacy, you should install plugins in the same location as RR software.
  8. #228
    Sep 2007
    its in same location....i checked plugin folder and they are there. i think i did legacy install? whats the diff?
  9. #229
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    It has nothing to do with legacy or profile. Assuming you've added the skin files needed where they belong, you need to edit the file which lists the available menu button options. Check out this post which explains how my pandora plugin was added to the available menu buttons list. Each plugin needs to be done in the same manner basically.
    Live mp3Car Facebook Chat
  10. #230
    Jan 2010
    Ohio
    Does anybody have the skins for RRMedia that they could share?
  1. FreeFone standalone alpha 1.1 Released
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-06-2010, 07:17 AM
  2. Replies: 16
    Last Post: 12-28-2006, 12:09 PM
