Page 9 of 29 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 288
Thread: eLite | 2 (alpha) Released 9-15-11
  1. #81
    Newbie Scratch's Avatar
    Nov 2009
    North Carolina
    +1 to you good sir
    Great skin, have it up and running. I like what you did with the garmin skin and the home button. Looks great keep up the good work
  2. #82
    Jul 2010
    Quote Originally Posted by Sonicxtacy02 View Post
    inside the skins folder there is a file called general.ini. Change the SHOWHEIGHT setting to 600.
    I did change the SHOWHEIGHT to 600, however, it still runs at 480. How can I do now?
  3. #83
    Sep 2011
    I run an 1024x600, by changing those values. Have noticed that some screens don't play ball. The garmin overlay is one I have found. Start splash screen is another, resized the master image to fix that one.
  4. #84
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by yd82 View Post
    are you sure you did SHOWHEIGHT and not ORIGINALHEIGHT. Make sure the setting was saved. SHOWHEIGHT works on all RR skins to change the resolution
    Quote Originally Posted by SteUK View Post
    RR has trouble stretching to that high a resolution on screens with embedded applications. It could also be a limitation of the overlay for that particular skin file.
    Live mp3Car Facebook Chat
  5. #85
    Sep 2011
    Inspect all of two minutes playing with the skin. I am sure it can be fixed up...should indecide to use Garmin It is a bit slow on a lowly eee 900.
  6. #86
    Woodbridge, VA
    Blog Entries
    41
    hacked together a skin for mobilephone.net. I figure the working indicator was crying out for a matching skin for the plugin
  7. #87
    Sep 2011
    Nice! Fancy sharing it??
  8. #88
    Mar 2008
    Hello,
    Any chance for Unicode support? None of my titles tagged in Cyrillic show up correctly - I only get empty boxes instead of letters. That would be terrific. Trying to switch from CF to RR. Your skin is the best!
    Thanks,
    --max
  9. #89
    Jul 2010
    Yes, I did change only SHOWHEIGHT to 600 and keep ORIGINALHEIGHT at 480. I tried on 2 computer and did not get any different result. Do I need to check anything else? I change the general.ini in the folder c:\Program Files\Riderunner\Skin\Elite2\general.ini . Is that the correct path?
  10. #90
    Nov 2009
    North Carolina
    That is the correct path. At least for me and it worked. Garmin sometimes does not play nice. Sometimes it loads and sometime it does not. I have not looked into it enough.
  1. FreeFone standalone alpha 1.1 Released
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-06-2010, 07:17 AM
  2. Replies: 16
    Last Post: 12-28-2006, 12:09 PM
