Page 1 of 29 1234567891011 ... LastLast
Results 1 to 10 of 288
Thread: eLite | 2 (alpha) Released 9-15-11
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    What is eLite II ?
    If you have enjoyed using eLite Lite, then you should like using eLite II alpha.
    Elite II is the updated version of eLite Lite that includes many features that are included with other skins. This is something that has been promised for awhile now and is getting closer and closer.
    Why is it in Alpha?
    This release is to allow the forum members to test the skin using different hardware configurations and to report any problems that they may encounter. A final release will include improvements and more plugin options.
    Here is a small preview:
    ENTERTAINMENT MENU
    AUDIO PLAYER
    VIDEO PLAYER
    ------------------------------------------------ ABOUT THE SKIN ------------------------------------------------
    FEATURES:
    • AUDIO PLAYER
    • VIDEO PLAYER
    • DVD PLAYER
    • RADIO PLAYER
    • HD RADIO PLAYER
    • XM RADIO PLAYER
    • SIRIUS RADIO PLAYER
    • IGUIDANCE
    • GARMIN MOBILE PC
    • EXTERNAL GPS
    • WEATHER
    • SKINS
    • BACKGROUNDS
    • SCREEN DIMMER
    • MIXER
    • EQUALIZER
    • EQUALIZER PRESETS
    • 6 THEME COLORS
    • MORE.....
    DYNAMIC MENUS
    • 2 ENTERTAINMENT
    • 2 TOOLS
    • 2 SETTINGS
    • 1 POWER
    SUPPORTED PLUG-INS
    • RRWEBBROWSER
    ------------------------------------------------ DOWNLOAD LINK ------------------------------------------------
    --------------CURRENT RELEASES--------------
    FILE SIZE: 12.5 MB
    FILE NAME: eLite 2 Setup.exe
    RESOLUTIONS: 800x480
    DOWNLOAD LINK: http://revonedesigns.com/
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    eLite II Installation Issues
    WHY ARE THE FONTS NOT WORKING?
    Depending on the mode of installation that was chosen, you will need to open the
    eLite 2 folder under the following locations:
    PROFILE MODE INSTALLATION:
    %MYDOCUMENTS%\Riderunner\skins\elite 2
    PROGRAM MODE INSTALLATION: %PROGRAMFILES%\Riderunner\skins\elite 2
    Open the folder call "FONTS" and install the font files.
    HOW DO I GET ELITE 2 TO RUN AT 800 X 600?
    eLite 2 was designed to run at 800 x 480; however, if you would like to run it at 800 x 600 the following changes will have to be made.
    Open the General.ini file in notepad
    Replace
    Code:
    ShowWidth=800
    ShowHeight=480
    With
    Code:
    ShowWidth=800
    ShowHeight=600
    Save file
    NOTE: THE GARMIN SKIN WILL NOT WORK IN 800 X 600.
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    eLite II Template Files
    NEW MENU ICONS TEMPLATE
    Please Note:
    These are not the same icons that were released in current release of eLite 2 Alpha.
    These are the standard icons that will be used in the new release.
    Download Here
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    eLite II Addons
    DASHCOMMAND
    1. Download the zip file and extract to the eLite 2 folder.
    2. Add the lines below to the files and you should be good to go.
    NOTE: IF WANT TO USE
    -startindashboards OR ANY OTHER PARAMETER IT MUST BE INCLUDED IN THE "dashcommandpath=" USING A "|" IN BETWEEN THE PATH AND THE PARAMETER
    EX:
    dashcommandpath=C:\Program Files (x86)\DashCommand\dashcommand.exe|-startindashboards
    This will give you a menu button instead of using the application launcher.
    Download: eLite2 - Dashcommand.zip
    Code:
    ADD TO EXECTBL.INI
    "DASHCOMMAND","LOAD;DASHCOMMAND.SKIN||RUN;$DASHCOMMANDPATH$;DashCommand™"
    ADD TO SKIN.INI
    dashcommandpath=SET THE PATH TO DASHCOMMAND HERE
    ADD TO APPLICATIONS.ELITE (OPEN IN NOTEPAD)
    LSTDASHCOMMAND||Dashcommand
    WEBRADIO
    Thanks to fruchtfliege, here is a skin for the Webradio Plugin
    Download: eLite2_webradio_skin.zip
    Newbie dandydanny's Avatar
    Jul 2009
    Los Angeles, CA
    You have not forgotten the wide-screen users! Looking forward to it
    Mar 2009
    Brazil
    Thumbs up
    Fantastic job.
    Jul 2009
    Looking forward to it.
    '05 Magnum RT
    CarPC coming soon. Hopefully end of 2010.
    Parts left to buy-
    Monitor, Bybyte frame, Axxess hook up, Sheet metal for double din case.
    Constant Bitrate WarningSLO's Avatar
    Dec 2005
    San Diego, CA
    Keep up the good work. Thank you for the time you put into this. I know our patience will be rewarded.
    My Worklog
    2006 Tungsten Grey GT | Dark Charcoal Leather | 18" Fanblades | Spoiler Delete
    C&L Intake | Bullitt Mufflers | MGW Short-throw Shifter | MGW Interior Pieces
    Newbie Huss's Avatar
    Dec 2007
    looking good...
    Apr 2006
    Sydney, Australia
    Very nice work there!
    Looking forward to it and an excuse to jump back to RR
  1. FreeFone standalone alpha 1.1 Released
    By CdRsKuLL in forum Software & Software Development
    Last Post: 12-06-2010, 07:17 AM
  2. Replies: 16
    Last Post: 12-28-2006, 12:09 PM
