Results 21 to 30 of 31
Thread: My first Skin - Audi - MMIV3
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by limoncello View Post
    Pierrot , did you find a source for camera information for gpsexec1 that gives you heading information?
    What do you look for exactly ?
    the gpsexec.ini file ?
  2. #22
    May 2010
    I have poi data, but i havent found any data that includes the heading information, ie in which direction of travel is the POI, i see there is the possibility to add the data in gpsexec but i havent found a source that provides it?
  3. #23
    May 2008
    Bordeaux, France
    Ho yes , this is the Maxhdg and MinHdg but i don't know how to calculate it.
  4. #24
    May 2010
    I have found one but it is a mixture of N, SW etc and text like "on the bridge" not very helpful and no speed which i really want.
  5. #25
    May 2008
    Bordeaux, France
    What is your need exactly ?
  6. #26
    May 2010
    i wanted to use the heading information to cut down the number of false alerts, ie if the camera is on the oposite side of the road etc
  7. #27
    May 2008
    Bordeaux, France
    A solution would be to define automatically the min and max heading, if it is not define into the gpsexec.ini file, calculate with the heading of the road where you are .
    A little change into gpsexec1.exe is possible for that, i think !!!
    For each new point , it is possible also to define the min and max heading with the same solution . But if you have a list of points without the heading it more difficult to calculate the heading for each point!
  8. #28
    May 2010
    apologies for the delays in returning, i still have a moderator OKing my posts
    if you could make a change to gpsexec1 to calculate the heading from your relative position, and ignore those that are not on your current heading we wouldnt need any heading information, just a var to allow the selection of how many degrees you want to use. ie if you are heading north and the poi is north +- X degrees it is not ignored, is this what you meant, it sounds like a good solution if you can make the changes? perhaps allow a couple of presets one for city and one for motorway driving where the degrees will be less
  9. #29
    May 2008
    Bordeaux, France
    yes it is that i want to do but i don't know if i can !
  10. #30
    Newbie Cheesegeezer's Avatar
    Sep 2008
    I love the look of this skin, got a really clean feel to it. Good job Sir!!
    The difference between genius and insanity.......... Is the measure of success!!
  1. Audi MMI Skin
    By predator1 in forum CF Skins
    Last Post: 05-18-2015, 06:11 PM
  2. New Audi Skin for RR
    By dbassix in forum RR Skins
    Last Post: 11-06-2007, 11:32 AM
  3. My first audi skin!!!
    By Getright in forum RR Skins
    Last Post: 11-07-2006, 03:01 AM
  4. new skin Audi
    By banditblue in forum NeoCar Media Center
    Last Post: 02-22-2006, 11:00 PM
