Results 11 to 20 of 22
Thread: NoName Skin... Proof of concept
  1. #11
    MySQL Error
    Oct 2004
    the skin editor is 3rd party program, and not DIRECTLY supported by the rr team, from time to time Bluezx3 does update it... i would think it would support the blink times..
    i tend to use a text editor to tweak a skin...
    we would love someone to do a new skineditor, or at least take ownership of this one
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Newbie Cheesegeezer's Avatar
    Sep 2008
    Just a little update as to my progress. I'd like to think I'm learning pretty quickly and my photoshop is taking a pounding but all good fun.
    These are actual shots from RR now, not a photoshop mock up. I still need to work on the browser window (I borrowed this from Carwings skin for the moment-Thanks). If you have any comments, suggestions or critics then please pipe up.
    The screen shots are from: Home screen, Home screen with an incoming call popup, Audio Player & Audio player with visualization.
  3. #13
    Jan 2012
    I like it, I want it, How long till done? :P
  4. #14
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Cool, good job who progress on the good way
  5. #15
    Sep 2008
    Cheers for the comments peeps..... much appreciated!! Always gives a morale lift
    @ Liam17 - I'm not very far along with it, probably be a month or so at least before the basics are complete, I will probably be looking for beta testers to make sure the core is working, then I can look at adding in extra features.
    I have to say, I like the "INC" txt documents you can create... it saves sooooo much time not having to reinvent the wheel all the time.
    Is there any documentation for creating iLists and folderbrowser windows?
    The difference between genius and insanity.......... Is the measure of success!!
  6. #16
    May 2008
    Bordeaux, France
    Quote Originally Posted by Cheesegeezer View Post
    See the "Skin Commands.txt" file under your RideRunner\Documentation folder.
  7. #17
    May 2008
    Bordeaux, France
    /, (SD) Directory List Properties -- (May be Extended later)
    /, a Disp w h Path Files ShowExt
    SD,AA,MODE,ICOW,ICOH[[[,PATH],FILETYPES],EXTENSION]
    The above defines extra propperties for the folder List on the current skin.
    AA is the Alignment of the Directory List (00=Left, 01=Right, 02=Center).
    Disp Mode sets the mode of display (00=Normal List, 01=Thumb Preview Icon List, 02=Thumb Preview Icons).
    Note: iLists require that you set Disp Mode to 03
    ICOW defines the Width of the Icon to display on display modes 1 and 2. (-1 hides icons for mode 0 & iLists)
    ICOH defines the Height of the Icon to display on display modes 1 and 2. (-1 hides icons for mode 0 & iLists)
    PATH defines the Directory/Folder location to display initially (OPTIONAL). If not present the path
    from the previous screen is used. Use "DEFAULT" for default path when needed. USE QUOTES.
    FILETYPES defines which filetypes to display. i.e. ".jpg.bmp.gif" -- "*.*" can be used for all files.
    EXTENSION defines if file extensions should be displayed. TRUE for displaying extension, FALSE otherwise.
    Example: SD,01,01,50,50,"$PICSPATH$","*.*",True
    /, (IL) iList Support
    /, List Par1 Par2 EndBMP Limit Drag MaxSpeed
    ILX,LIST,PAR1,PAR2[,ENDBMP[,LimitMode[,Drag[,MaxSpeed]]]]
    The above modifies a list object to be displayed in "iList" mode -- required DirectX 7 or above.
    An "iList" is a list with smooth-rolling capabilities which can be "dragged" and "thrown" with the finger.
    LIST defines the list: PL (Playlist), DL (Directory/Folder List), PB (PhoneBook List) or CL (Custom List).
    PAR1 and PAR2 define if the list is Bitmap based or Text based. For Text based PAR1 and PAR2 define colors
    used to draw the list. For Bitmap based, PAR1 and PAR2 specifile BMP files used for drawing the list.
    For Text based, PAR1 and PAR2 should be in RRGGBB (HTML color) format starting with the word "RGB".
    For Bitmap based, PAR1 is the UNSELECTED item bitmap, and PAR2 is the SELECTED item bitmap.
    ENDBMP defines the "End Marker" bitmap to be used (Optional) -- On Text mode, it's a separator text.
    LIMITMODE defines the type of limit for the list: 0=FreeRoll (No Limit), 1=Full Stop, 2=Sticky (Default).
    DRAG defines the amount of drag when throwing the list -- Range: 1 to 100. Default=70.
    MAXPSPEED defines the maximun speed of scroll/throw -- Range: 10 to 100. Default=50.
    NOTES: For Dir Lists, you should specify folder/media bitmap files in the header of the .skin file (3rd Line).
    If you don't specify those files, the list will not display icons (No icons stored in RR for iLists).
    The Folder/Media files MUST BE BMP FILES for ilists.
    Examples:
    Playlist using bitmaps, no end marker, Full Stop limit, default drag, default speed (Both work):
    IL,PL,unsel.bmp,sel.bmp,,1
    IL,PL,unsel.bmp,sel.bmp,,1,70,50
    Directory List in Text Mode, *** as end marker, Free Roll, drag=20, max speed=70:
    IL,DL,RGB000010,RGB00F000,************,0,20,70
    Directory List using Bitmaps, end.bmp file as end marker, Free Roll, drag=20, max speed=70:
    IL,DL,unsel.bmp,sel.bmp,end.bmp,0,20,70
    Custom List in Text Mode, no end marker, Sticky Stop, drag=50, max speed=60:
    IL,CL,RGB101010,RGB0000F0,,2,50,60
    Text Mode Transparency: PAR1=RGBFF00FF -- Also works for PAR2 for a Transparent line when PAR1=RGBFF00FF).
    IL,CL,RGBFF00FF,RGBFF00FF,,2,50,60
    Bitmap Mode Transparency: PAR1=TRANSPARENT.BMP -- File MUST exist, but its contents are ignored.
    IL,DL,transparent.bmp,sel.bmp,end.bmp,0,20,70
    NOTE2:
    When using Bitmap Transparency, PAR2 and ENDBMP (Sel.bmp and end.bmp in the example) can have transparent areas
    by simply making areas with the RGB color FF00FF (Full Pink) -- You MUST however is to make sure the size of
    the BMP file is AT LEAST THE SIZE IT WILL BE DISPLAYED -- otherwise, you may loose the transparency effect
    due to stretching of the pixels when loading the image.
  8. #18
    Sep 2008
    Sir, you are a legend!!! Very useful information and thanks for posting the quotes.
    I assume that these are stored in the xxxx.skin file and not in the ExecTBL file?
    Thanks again.... more food for thought.
  9. #19
    Sep 2008
    Another little update.......
    Also embedded dashcommand, only thing left to do is equalizer, settings and mobile phone for the core to be working
    Anyways some more screen shots. I've decided to call it XEON for whatever reason, although I'm up for suggestions if anyone wants to pitch in
    MOVIE BROWSER
    MOVIE PLAYER
    DASHCOMMAND
    NEW AUDIO PLAYER
  10. #20
    Sep 2008
    Is there a way to get movie folder art (i.e. folder.jpg, folder.png) to show? I've searched all the supplied documentation, and tried coverart, albumart, folderart... just from reading the forum and also the skin settings.txt.
    Any help would be great
  1. RR WebRadio - Proof of concept plugin (SOURCE TYPE)
    By mitchjs in forum RR Released Plugins
    Last Post: 01-02-2015, 04:46 PM
  2. Hyundai Haptic Proof of Concept Uses PC - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 01-07-2011, 02:18 PM
  3. Proof of Concept: Interfacing with GMPC
    By ws6vert in forum Garmin Mobile PC
    Last Post: 12-22-2010, 03:49 AM
  4. Proof of Concept Help ion 330ht-bd
    By sliblue in forum Newbie
    Last Post: 12-06-2009, 04:02 PM
  5. Ready: NoName Skin for FD1.0
    By Bravellir in forum FD Skins
    Last Post: 06-06-2006, 12:01 AM
