Page 1 of 6 123456 LastLast
Results 1 to 10 of 55
Thread: OMEGA/Transparent
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    OMEGA/Transparent
    My new skin is allmost finished, but I can not decide about the transparency level. I would like some input from you guys, I sure can't make up my little mind. Here are some shots with the top and bottom bar solid and transparency of 50%. I will (maybe) include color schemes for the foreground, when you have a light background then you can change the font colors.
    Which one is better?
    Oh, and thanks, yell away...
    Constant Bitrate Gixxer's Avatar
    Jun 2005
    Daphne, Alabama
    I like the transparent better I think. But with that being said, it almost takes away from the buttons. Either way both are very nice. As always. I'm really diggin the shutdown menu.
    Jan 2007
    dundee, il
    i like the transperant as well, but i actually think it makes the buttons kinda pop out more. either way, it looks like a nice skin
    david
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    i like the trasparent too
    but i'd add some transparence to the buttons to
    check the SE2 from Tensai. guess thats the way to go with your skin too
    []s
    Oct 2006
    CT
    both look good, it would probably be personal preference.
    How about if you let the user decide from settings on transparency, if its possible.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I tryed that before and set transparency to the buttons but looses alot of contrast depending on the background, so I decided to leave them alone. I will keep it semi with full buttons.
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    The transparencie kind of makes the clock hard to see, maybe try a different font.
    New Age Garmin - Skin for RR
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    transparent is good i like it better
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I think you know my thoughts on this, Transparent!!! Love the LCD clock. Confused at the screenshot of a chrysler emblem and a benz S class ?? Really nice work as always MGD. How are you going to handle font color switch?> Since a lighter background needs dark text and vice versa.
    Nov 2005
    really nice work MGD!
