Originally Posted by
blackandblue
Did you open the builder.ini file and put in your
music path first?
One question for Sonic (btw, awsome skin). If I want to change one of the menu links (lets say
Radio) and have it open an external app (Hondata, for my ECU monitoring), how would I go about it? Do I have to setup a .skin and .swf file for it? I did it in my current skin (simplistique) and was able to copy the 'solitare' .skin file and use that one for my Hondata app. I notice it is all in flash, which I can't edit, so is there an easy way to do it? Or just a blank skin that calls an app?
first what you wanna do is make a copy of base.skin in the skin folder. Rename it to hondata.skin or whatever u want it to be. From there u wanna edit the skin.ini file changing one of the mainbut#'s to load your hondata skin with your hondata app. So it would go something like this...
Code:
&mainbut5=Hondata@LOAD;hondata.SKIN;Hondata;C:\Program Files\Hondata\Hondata.exe;Hondata&
this will embed your application (assume that file path and window title above are correct) into the hondata.skin. Please note though Hondata does not currently have an icon built into the main skin so you wont see an icon but its button. This will change on the final release
Nola111
Sonic, I read earlier in this thread that you based this around
IGuidance 4. I have iGuidance 3. Will it work?
it will work with ig3 just fine.. no modifications needed
