Blue ZX3,
Downloaded your RRConfig, ran it, made some simple changes, and saved.
AND DigitalFX works just fine up to the point that I am missing some bits that I will look into tomorrow.
Thank you.
Regards,
Jim
P.S. For the sake of knowledge, what dioes GDI refer to?
Graphics Device Interface
...JJG
How are you running your speakers? Are you running separate outputs from your sound card to a four channel amp? You can always just try enabling CMSS on your Audigy and see if that works..
Speakers are being ran by the factory amp, which ran all the speakers before. Like I said, MP3's play fine in all speakers. Just the radio is being difficult. The CMSS is running, thats how I get the MP3's to play in all. It has to be with the line-in.![]()
I found that only programs that use DirectSound for output play through all my speakers
windows itself doesn't use it that's why the sounds in windows like startup & shutdown etc.. only play in the front speakers
But games of course use it so all speakers work
A lot of that depends on how you have your sound set up. Quite a number of sound cards don't handle multi-channel audio well. One particular card had a noticeable delay between the front and back speakers with the 4-channel emulation it used.
Are you outputting stereo or surround? If your factory unit is taking in stereo then its just mirroring the front to the back, or doing its own type of surround processing. If you have to run CMSS to get your MP3's to play on the rears, then I assume you are outputting surround. This would help in figuring out your problem..
Good news. I found out the 'linein' program that comes with winamp doesnt work. I DLed the one from their website and I now have sound in ALL speakers!
Thanks for the help.
Now, one more 'problem' to solve and I'll be 110% happy with a CarPC.![]()
