Great news! If you post the link to that download page here, I will put it in the 2nd post in this thread for others to try as well.
Printable View
That's a fair trade off. In my case it was SPDIF audio over analogue.
Using Visteon HD Radio and Mitch's serial cable I have been attempting to get RR to work with it using dfx3.0. When I place a button for HD Radio on the menu and then use that to access the HD Radio, it will not turn on(power on) the unit. If I use mitch's PCR software it works fine. I did register the dll from the /roadrunner/hdradio directory and rebooted.
What am I doing wrong? Can some one please give me some ideas on what to look at?
Run RRConfig.exe and select the HD Radio from there, also the audio line you using for the tuner. Look at the RR.ini file if you see those lines.
[Radio]
radiomode=8
allowallfreqs=false
radioline=3
userbds=true
Then it should work.
Hi
this is more great skin...
but I have one problem, when I click on clock RR close :nutz:
what is the problem, some one can help me?
is possible change clock? and put oder clock or an logo?
regards
My suggestion would be to read some of the last couple of pages and you'll find your answer..
