@PontiacGA
under output are you using "Nullsoft DirectSound Output"
I don't need a line in plugin as long as I use this for output
But if I use "Nullsoft Waveout Output" then I would need it
Printable View
@PontiacGA
I have limited space. I doubt a full sized sound card will fit.
Yeah, read that. Well, if I cant get rid of the stupid echo.... I dont wanna my stereo to sound like a music hall that turned out bad.
I *think* the solution to this is posted on the first page, second message.
You have to change one of the buttons. Just 'click' and hold the button on either of the menu's and a list of different buttons will pop up. Just choose the 'browser' button.
CWorks:I think I have to use the line-in utility, or I only get 2 speakers working.
Hi
but I install flash player...
now I have other problem... when start RR CPU go to 100% and dont exit ...
have some solution?
A question.
Is there anyway to get more room for XM channels on the XM skin.
I have 12 favorites which is what the other skin I use allows on one page without scrolling. But DigitalFX3.0 only allows 9 and you have to scroll to see the rest.
Is there anyway to have 12 showing? Maybe smaller fonts or get rid of the satellite signal bars and make more room?
Also can a clock be added in the XM skin ?
Thanks and thanks for the wonderful skin.
Would someone let me know what I'm doing wrong to get my cpu and hardrive temp to display correctly. Using speedfan and showspeedfan, I renamed my readouts per showspeedfan in the speedfan config and in the menu and menu2 skin files I changed the Temp1 and Temp2 variables as such:
F,240,413,319,73,"BDCompass.swf"
IMG,269,166,255,255,"BDLogo.png",
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT0","left"
L,0,0,0,0,#DFX1R#,#DFX1G#,#DFX1B#,0,"Arial","GPSSP D","CENTER"
Now when I run RR, the menu displays "Interior = Left Computer= Left". I'm sure this is simple, so what did I do wrong?
Thanks in advance. This skin rocks.
Copy and paste this code and it should work.
Sorry, forgot, you can NOT justify those speedfan labels....Code:F,240,413,319,73,"BDCompass.swf"
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","SFT2",
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Computer:",
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Interior:",
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","SFT0",
L,0,0,0,0,#DFX1R#,#DFX1G#,#DFX1B#,0,"Arial","GPSSPD",
