Thread: DigitalFX 4.0
  1. #1071
    Dec 2007
    Gonzales,LA
    5.13...Nothing newer, Nothing Older! Has been tested to be the most stable and most compatible with this skin..
    Thanks........I also did a fresh install of windows so hopefully everything pans out but again thanks......
  2. #1072
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question can't get HDRadio to work in dfx 3.0 skin
    hi, i tried and tried but not luck. i followed the directions on how to install dlls from mitch........... (make sure
    HDRadioComm.dll
    RegAsm.exe
    RunMe1st.cmd
    UnRegMe.cmd
    are in the same directory
    and run RunMe1st.cmd
    this will register the .dll as a com object
    and generate a .tlb for programming
    a good dir is
    C:\Program Files\Common\MJS Gadgets\
    -Mitch i did this over and over and still no luck. i could play my visteon hd radio with the HDRadio PCR Program outside of roadrunner and dfx 3.0 skin no problem but, it won't work inside rr. What could i be doing wrong? Please Help......... Thanx a Bunch.
  3. #1073
    Dec 2007
    Gonzales,LA
    OK still the music browser shows no music......Im missing something i jus know it
  4. #1074
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by chvybeatsford View Post
    did you set the audio file types in rrconfig?
    you need to add at least .mp3
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
  5. #1075
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by THEREALRAWPWR View Post
    HDRadioComm.dll
    RegAsm.exe
    RunMe1st.cmd
    UnRegMe.cmd
    a good dir is
    check your rr.ini file for radiomode=8 and hdradioport=? (whatever port # you are connected to)
  6. #1076
    Dec 2007
    Gonzales,LA
    Quote Originally Posted by DaveDog View Post
    Yes its set. The only way to get anything to play is if i open win amp before RR and move files into there then open RR i can play the files but browser still empty.
  7. #1077
    May 2007
    Question HDRadio still won't work.......
    hi, davedog thanks for helping but i still can't get hdradio to work. this is whats in my rr.ini file - [Radio]
    radiomode=8
    allowallfreqs=true
    radiatorpath=C:\Program Files\Radiator\
    radioline=1
    uselineinplugin=true
    lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
    resetradio=
    userbds=false where is hdradioport= ? it's not in the rr.ini file .i did everything i was suppose to do right? i was wondering if you could type down in easy to do steps on how you made hd work . as i said it works ok outside rr and dfx 3.0 . i need this to work i don't want to use radiator and d-link radio anymore which suck ***. thanx again.
  8. #1078
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    I have come to the conclusion that there is a configuration problem somewhere in the DigitalFx Hd Radio skin.
    I can get HD radio to work perfect in every skin I try EXCEPT the DigitalFx 3.0 skin.
    Must be a problem with certain settings. I'm running Vista so that may be a problem also.
  9. #1079
    Mar 2004
    Greenacres, WA
    radiomode=8
    allowallfreqs=true
    radioline=1
    resetradio=
    add the line
    hdradioport=x
    to the rr.ini file. this needs to be done manually, x= the com port number, i.e. 3
    my rr.ini file reads as follows
    [Radio]
    radiomode=8
    allowallfreqs=false
    radioline=5
    userbds=false
    hdradioport=3
  10. #1080
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    yeah you need to add the hdradioport line... its not automatically there.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
