Like Tree1Likes
Thread: DigitalFX 4.0
  1. #1081
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question still nothing..........
    i have the port listed now in rr.iri. also i went to device manager an it states that i have 2 in use ports #2 and #3 . i tried both i rr.ini and still nothing .also i notice that outside rr & dfx3 you can hear the visteon hd tuner click on and off ,but not in rr & dfx3. why?
  2. #1082
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by chvybeatsford View Post
    Yes its set. The only way to get anything to play is if i open win amp before RR and move files into there then open RR i can play the files but browser still empty.
    Have you set the musicpath in rrconfig?
  3. #1083
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by THEREALRAWPWR View Post
    the clicking is from the serial ports RTS/DTS lines changing state, this is normal.
    it still sounds like you do not have the correct setting for hdradioport
    will the standalone HD radio app tell you what serial port its using?
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  4. #1084
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    HdRadio
    The HD Radio new DLL's go in C:\Program Files\Road Runner\HDRadio to work with RR and DFX. You need to unregister the old DLL before overwriting and registering the new DLL.
    Then check at the very bottom of rr.ini for the hdradioport=x setting. Mine had one there already and I had added it again with another port, so I had 2 and it wouldn't work till I got rid of the extra one.
    ...JJG
  5. #1085
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I am not sure it is a skin related problem, as I am using HDRadio here, as well as many other users from what I have seen.
    If the radio is turning on and off (Clicking twice), that sounds like a problem there, as when initialized, it should just turn on, when software is closed, you will then hear it turn back off.
    Check your rr.ini for other devices using the same com port, such as Sirius, XM, or other radio devices you may have set up in the past.
    My Fiero Build Thread
  6. #1086
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    FWeather Problem:: I have been using RR and Digital FX 2 and 3 for months now. I have always been able to use the weather flawlessly. Today when I went to use it after doing absolutley no changes to the system in 1 month, the weather is not working. When the weather screen comes up the SAT and RADAR maps load and are current, however the general weather for the selected location is blank. Where the Time/Date/ location would be at the top there is just 2 dashes appearing in this manor: - -
    I have a good internet connection and everyhting else works, Traffic/Net Radio/Jukebox etc... I checked the RR.INI and the config. Nothing has changed.. I also visited weather.com outside of the skin to see if maybe it was a problem on their end and all was well. Any ideas? Thanks.
  7. #1087
    Nov 2007
    PA
    I see way back in the threads there is a similar problem, however no real resolution or reason given. I have read all the helps and am familiar with the settings....
  8. #1088
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Dougw133 View Post
    DigitalFX 4.0
    Might need to put that in the FAQ (post #2) John.
  9. #1089
    Nov 2007
    PA
    Well then...................... That makes sense haha. Thank's alot! I can stop pulling myhair out, however that does suck big time!! I really liked the weather feature.
  10. #1090
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automationÖ
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
