Thread: DigitalFX 4.0
  1. #1111
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Look in your RR.ini file for those lines.
    [Radio]
    radiomode=8 >>HDRadio
    hdradioport=1 >> Your Com Port
    allowallfreqs=false
    radioline=3 >> Line In or CD Volume
    userbds=true
  2. #1112
    Jul 2007
    Also, if you use iGuidance, it lowers your line-in volume to 0 for some reason (I started a thread on that problem). So make sure that your line-in volume is correct.
  3. #1113
    Apr 2008
    DFX3 and MP3/Radio display data at top of screen
    When I change to another screen from say radio, to GPS, the status screen at the top still shows the last MP3 I was playing even though I'm on the radio, I would like it to show the current station along with the RBDS data instead, Is this possible?
    BTW, HD radio works great and rocks!, as well as does this skin.
    randy
  4. #1114
    Apr 2007
    France/Paris
    Lyrics
    How does it work? I've already embed lyrics in my songs. and now?
  5. #1115
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by randyre View Post
    Unfortunately that is the way the plugin works. It only displays the information on the HD Radio skin.
    Quote Originally Posted by Cob94500 View Post
    You should be able to just click the song name in any of the skins, and then click lyrics at the bottom.
    My Fiero Build Thread
  6. #1116
    Constant Bitrate Pseudo Nim's Avatar
    Apr 2005
    in the snow
    Hey all,
    Having a strange issue. Searched the thread, but don't seem to be an answer for this. Basically, I get no MP3s in the music browser. Nor do I get any directories. Nor does the playlist window work (and it locks up if I use it). If I switch to the BMV2 skin, I have no problem picking music etc. If I then switch back to DFX3, it _has_ the playlist and it _will_ play music but if I go to the Audio Browser, the screen will be empty; and if I go to the Playlist Editor, the controls stop responding and I can't click anything anymore.
    Anybody encountered this?
    -pN
    Doko ni datte, hito wa tsunagatte iru...
    My BMW 335xi install
    My Subaru Impreza install (now retired...)
    Realtime audio freestyle hiphop battles online - www.letsbeef.com!
  7. #1117
    Jul 2007
    Quote Originally Posted by Pseudo Nim View Post
    Hey all,
    -pN
    Probably a problem with iLists. Disable that and check if it works. If so, then make sure you isntalled DirectX and the latest drivers for your video card. I had the same problem (I hadn't installed DirectX).
  8. #1118
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    CDMA Phone/Dial Up Network support?
    I have been using a CDMA phone for my internet access. Any way or maybe in the next release to support the connection? ie. A connect and disconnect button/screen? Thanks a lot...
  9. #1119
    Apr 2005
    in the snow
    Quote Originally Posted by Dgege View Post
    I'll take a look. Should have DX installed.... then again, I'm running TinyXP so who knows. Is iLists a separate plugin I should install btw? For some reason I thought that was part of everything, but if it's not, oh boy will that be silly
    Thanks!
    -pN
    [EDIT] Just reinstalled DirectX and checked for updated drivers - no luck. Turning off iLists fixes everything, but I kind of like the idea (I don't know what they do, just suspecting).
    Any ideas why iLists might be broken? I did a full install of Winamp 2.95 with RR.
    [EDIT #2]: After having found this post, I turned off ID3 tags, and now things work fine. Looks like it was related.
    Thanks!
    [EDIT #3]: Very weird. Still, in some places, the skin stops responding to mouse control. I just went to Task Manager, and in the window that popped up, I couldn't click on anything, and I had to use Windows Key + Shutdown + Reboot to get something back. Anybody seen something like this happen? I'm a bit worried how the car will perform, seeing as I don't have a keyboard handy....
  10. #1120
    Apr 2008
    OK, sort of got this fiured out, I was able to cut and past and modify from the radio skin, but this all makes it real permamnent. Is there any way for it to use a variabe and know weather its an MP3 or the radio playing and use the proper display?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
