Thread: DigitalFX 4.0
  1. #1231
    Sep 2007
    Question possible suggestion
    Hey JohnWPB,
    DFX is simply fantastic!
    One possibility (and hopefully this is the right place to suggest an idea):
    In the XM window I can save the current artist/song to a textfile with a button. It would be mighty cool if the Jukebox could use that list to fetch? Sometimes I'm not "online" when driving, so the ability to fetch later in Jukebox might also be desireable?
    Is that even possible?
    thx for all the great work!
  2. #1232
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Ok, that glassy look above by nitra is in the works That is exactly what I wanted the skin to look like when I started 3.0. Hopefully all works out, and that will be an alternative to the way the skin looks currently.
    As far as tagging songs, and saving them in the jukebox, that is an idea for sure, but at the same time not one I was wanting to peruse. The jukebox was actually something I did for myself, and really did no mean to release to the masses. If someone wants to take over that area, and release something to go along with the skin, that is fine, but not something I personally am going to work on.
    As yet another note Thanks to all that contributed to the "beer fund" with the donations to PayPal, I put it to good use last night
    My Fiero Build Thread
  3. #1233
    May 2006
    Calgary, Alberta
    I can't download the file.
    "[path]\DigitalFX3 could not be saved because the source file could not be read."
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #1234
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I checked the FTP server, and the file is still in place, and I just tested the Download here with Fire Fox, and it is working ok.
  5. #1235
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Cool So far So Good...
    DL'd and installed today. Great skin. Still some tweaking to do - mitches cable on the way and garmin to install. John great job once I get all of it working I will do my best to look out for your effort.
  6. #1236
    May 2006
    Calgary, Alberta
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  7. #1237
    Mar 2008
    South Carolina
    Cool ^^^^^^^Works^^^^^
    I went to Johns site and DL'd . It work for me Prob might be on your end. J/K
    Also nst6563 DL'd your Garmin wide.zip in the readme you said add these lines in the Exectbl.ini file would that be in the same area as the ig parts? If so before...after? Got the software just to dang hot outside to install.
  8. #1238
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    test
    The Forum screwed up and put posts in front of the first post in this thread. I had to move some things around, and lost the post by Pseudo Nim, so it follows here:
    Pseudo Nim Wrote: I found two strange bugs with the skin (or RR? Forgive me if these are RR bugs). Anybody know if there are fixes or if there is something I should do?
    1. When I click "Browser", I cannot scroll through directories, I have to first _tap_ the directory window, and only AFTER that it becomes possible to use the scroll arrows (seems to be a focus issue of some sort).
    2. At times, DFX just stops responding to mouse clicks. It's as if the whole interface just locked. Absolutely nothing can fix it - the computer needs a reboot (or, if you have a keyboard connected, Windows Key + U + R + Enter (shutdown/restart).
    1. Hmmm I have not seen that happen here, not sure what could cause that, but it does sound like a focus issue. The strange part is the button codes "talk" to the list, so are supposed to "bring it into focus"
    2. Can you hit Ctrl Alt Del and see what the CPU is doing, and what is causing it?
  9. #1239
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    My question is when is the next update coming. I know your update is based on Blue's media browser release date, but from reading there are some other cool features that are incorporated in the rest of your release.
    Thanks.
  10. #1240
    Jun 2007
    St. Louis
    I updated the skin slightly, added the current song in the format Artist - Title to the right side of the lower screen in the un-used space.
    @ insaneramman - The lines go into the sections of the ini that they are in the readme. Not sure how else to explain it...
    /----------------- Dynamic Menu Buttons -----------------------
    / RR Command to execute when button is pressed
    is a section as is
    /----------------This is the label that is displayed on the Main Menu Buttons ----------------
    just like
    / These are the labels for the application that will show
    / up on the screen that gives the selection of buttons to choose from
    in your ini, look for those sections, and the code will go in there, at the bottom of the section usually. In the SetApplabels line, you'll basically need to add <<=Garmin at the end.
    Attached Files Attached Files
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
