Thread: DigitalFX 4.0
  1. #1291
    May 2006
    Calgary, Alberta
    Quote Originally Posted by TiBook_Swe View Post
    I also got the problem with the vertical-bar instead of the skin? I have the latest version of RoadRunner installed but still it's not working??? I donwloaded the skin to try it on my home-computer instead of my car-computer, but there the installation stops at 30% (just like someone else got). But I only want a solution to get it to work in my car. This skin seems awesome by the pictures, so ofcourse I want to try it out .
    i'm assuming the verical bar is about 30% the way across the screen and is mostly green or transparent? You need to update your flash engine. I've seen that before.
    But the download stopping at 30%....YES! Someone else with my problem and I don't have another computer to download it on, just my Blackberry. I could try that I guess.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #1292
    Sep 2005
    I've got everything to work now...Suddently it worked (didn't change anything )
    But just so u know, it's not the download hat stops, only the installation-wizard.
    This skin seems pretty cool now when i have tried it for like 5-10 minutes
  3. #1293
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by bambam View Post
    Hopefully this is a quickie. I've looked all over trying to find an answer to this but without any luck.
    Simple question, I want to train Dragon Dictate to send a command to RoadRunner (obviously, DigitalFX skin) but don't have any idea what text to send.
    What should Dragon Dictate send to RoadRunner, say for instance, to switch to GPS screen?
    Any help is appreciated and thanks in advance to all who reply.
    Edit: I tried the builtin voice control and had no luck so that is why I am trying to use Dragon Dictate which seems very accurate from my "training" sessions...
    you might want to start a new thread for that, cause it's really not DFX dependent, it's RR.
  4. #1294
    Jun 2002
    Virginia
    Quote Originally Posted by Maheriano View Post
    Can someone please host this download on a mirror? I've been trying to download it for days and always get the same error.
    Are you using Hughes satellite for Internet by any chance? Back when I was using that I couldn't download from the site either. Like you, I was the only one having the problem. I never figured out what it was about John's site that Hughes didn't like. If I were you, I would take a flash drive to a friend's house and try from there.
  5. #1295
    Jun 2002
    Virginia
    Blue,
    I'm getting this error message when running the button editor.
    (I did make the change to the first line of exectbl per your post above.)
  6. #1296
    Newbie GhostRiderDad's Avatar
    Apr 2008
    I had an error in DFX 3 that was strange. I tried to access the mileage part and when I tried to enter something, I got what looked liked a transparent keyboard with nothing on it. Is this a known bug?
  7. #1297
    Feb 2008
    Quote Originally Posted by kbreeden View Post
    Blue,
    I am getting this error as well
    1997 Pontiac Bonneville RIP 10/29/09
    1997 JEEP Grand Cherokee
    Software: (|||||||---) 70%
    Hardware: (|||||||---) 70%
    Car PC Install (----------) 0%
    HuntingKnightSM
  8. #1298
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You guys must have changed something in your skin's exectbl file as that line should have fixed it. I'm panning on giving it some more AI (Artificial Intelligence), some rework is needed.
    One of you attatch your skin exectbl.ini file, and I'll see about a quick fix till I add that AI.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #1299
    Jun 2002
    Virginia
    Blue, this message is different than the one that comes up if you don't change the first line.
    I had made some manual button changes through exectbl months ago. Does your proggy require that exectbl.ini is totally in its original form except for the first line modification you mentioned?
    Here's my file.
    Attached Files Attached Files
  10. #1300
    Feb 2008
    Here you go
    Here you go Blue ZX3. I made it into a txt file to upload it.
    HuntingKnightSM
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
