Thanks guys, I will check those...
I did change my mind, instead of a quick fix I'm going to just fix it as a whole. 1/2 done already!
@kbreeden
The one that is currently posted, yes. The next one will not matter as the AI will compensate for it.
For you to fix untill next update, these need to be in this order, can be located anywhere, just keeping the order..
#1
"SetApps","SETVAR;AppToRun;MyApp01<<MyApp02... .."
#2
"SetAppLabels","SETVAR;ButtonLabel;=MUSIC<<=RADIO....."
#3
"MyApp01","AUDIO"
"MyApp02","XM" ... ect
#4
"SetCommandLabels01","SETVAR;MyApp01LB;Music||SetCommandLabels02"
"SetCommandLabels02","SETVAR;MyApp01LB;Music||SetCommandLabels03" ... ect
LinkBack URL
About LinkBacks
...Honest enough question. Yeah, I clicked on file then save when I edited the exectbl (I assume this is the file you're asking about)
When I first create a new button, it shows up in the 'holdbutton' menu as a blank button. Not till after I added DynamicMenu Button 'MyApp48', a corresponding 'SetCommandLabels48', an entry for SetApps of 'MyApp48' and its SetAppsLabel did the button show up correctly in the "HoldButton' menu. I even tried opening the RR app under settings and did a 'save and restart' thinking that would fix the issue.
