Thread: DigitalFX 4.0
  1. #1341
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    Have you used the one from the second posting of the editor?
    That is what comes up.
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  2. #1342
    Feb 2008
    stonestatue
    Open the exectbl.ini file and replace the first line with this.
    Code:
    / DigitalFX Skin Code & Commands
    1997 Pontiac Bonneville RIP 10/29/09
    1997 JEEP Grand Cherokee
    Software: (|||||||---) 70%
    Hardware: (|||||||---) 70%
    Car PC Install (----------) 0%
    HuntingKnightSM
  3. #1343
    Feb 2006
    Did that, now this comes up:
    "Line -1: Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded."
  4. #1344
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    I'm just about set to put my pc in the car but I have one last problem within DFX.
    First off, I am using WinDVD as an external video player because I couldn't get the internal to work. The problem now is that when I have a video file selected, pressing the play button does nothing. If I press the Sel option on the left, that does nothing. The only way I can get it to play is to double click on the file name in the list.
    I changed the skin to BVM2 for testing and everything worked great. In fact, if I selected a folder that contained movie(s) and pressed the play button, it would play all the movies within the folder (the way I thought it should work).
    I noticed that there is a windvd skin in the DFX folder. Should I use this skin and if so, what is the easiest way to set it up?
    I did a search in this thread on WinDVD and it came up with nothing.
    Thanks in advance to all responses
    EDIT:
    I looked at the BVM2 button code for the play button and then went into the DFX video browser skin and changed the PLAY button to B,299,525,100,73,"SELECT","SELECT" and everything works great. Hope this helps others.
    Now, just for the hell of it, I'd trying to find how to use the windvd skin. I tried changing the names to video_player#### but no go, it messed up everything.
    "Imagination is more important than knowledge." -AE
  5. #1345
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have replaced the newest version with the first posting, so try it again.
    @stonestatue
    If you still have issues, you can attach your dfx exectbl.ini file and I'll check whats the hang up.
    @HuntingKnightSM
    That is no longer needed in the second version, as I took out that requirement.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #1346
    Feb 2006
    Where is the link for the program?
  7. #1347
    May 2008
    San Jose, CA USA
    Quote Originally Posted by bambam View Post
    EDIT:
    Use Winamp..just select the exe file for external apps
  8. #1348
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    For the time being... I added it to my sig
    See below...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #1349
    Feb 2006
    Alright, it works now. Thanks.
  10. #1350
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    Quote Originally Posted by mnickolson View Post
    One Question. How to make the clock on the main pages above the logo larger?
    Anyone ever answer this question? I'm now wondering the same thing.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
