Thread: DigitalFX 4.0
  1. #1411
    Jul 2008
    For the weather, you need the newest RR. The milage&trip screens were not finished b/c John couldn't get the mileage plugin working as the documentation for it wasn't updated when Festy updated the plugin, so its kinda hard to figure out what are the correct button & label codes to use.
    RR-last version
    Thx, but on my home PC i see "Weather" :/
  2. #1412
    May 2006
    Chicago
    I am using iGuidance UMPC 4.0, RR 11-2-07 (but I downloaded the new .exe 670 KB), and DigitalFX 3.0 (of course)
    When I click save location I get the dialog box (Current Location) with the info on where I am at and the save button. When I click save the window goes away. When I go through the same proccess in iGuidance (stand alone UMPC) after I click save in the "Current Location" dialog box a second dialog box (Add to Favorites) comes up and I am able to Edit the name of the location or simply click OK to save.
    So long story short, I cant get it to work in RR.
    I search around a bit for this and had a look at the .skin file myself but I dont see why this is not working.
    Thanx, Lew
    I am the stig's cousin.
  3. #1413
    May 2006
    Chicago
    Alright. I have hacked around with this for a few minutes and found a "work around".
    I commented out this line like so
    Code:
    /B,1,450,75,72,"SENDKEY;c",
    and added this line
    Code:
    B,1,450,75,72,"SENDKEY;%{f}{l}"
    This will go straight to savign the location (not bring up the current location info)
    This works okay, but it would be nice if it worked properly the other way. ex. Bring up the info and then click save and bring up the dialog to edit the name and/or just save it.
    Edit:
    I have settle on this:
    Code:
    B,1,450,75,72,"SENDKEY;%{f}{l}",@SENDKEY;c@
    If you press "save location" it will just bring up the "Add to favorites" and you can do so (it works). If you press and hold "save location" it will bring up the current location dialog (selecting save still does nothing).
    It works, Lew
  4. #1414
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Good info. Thanks.
  5. #1415
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi gang,
    I'm trying to get my SN working and have some questions:
    1. when I enter a onskinstart command line in rrconfig, DFX menus button's don't get text and don't switch to their respective functions. I noted that there's a exectbl file within the DFX skin folder, does this file have to have the additional onskinstart command listed in it? Or must I somehow append the command to the one already listed.
    2. Similarly, if I want to have the SN send commands (to say, switch to a different screen) where do I place those?
    Sep 2006
    War-Town, GA.
    What in the world is a "SN" - Snot Nose?
    But yeah, you can't have onskinstart in two places; add your new command to the back of DFX's.
  7. #1417
    Aug 2006
    PA
    Thanks treetop,
    SN = Space Navigator.....
  8. #1418
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    best idea is keep everything in the DFX exectbl, look for the onskinstart line in there, and add your bit to the end of it divided by ||.
    remove any lines you have addd to another exectbl and just use John's 1 inside his skin folder.
    as for any cmds you want to add , add to the same file, would be best on a separate line.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #1419
    Aug 2006
    PA
    Is there a listing of commands the RR / DFX would respond too?
    ie: if I send a command named "Audio" would RR/DFX translate that into loading the Audio screen?
  10. #1420
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Skincommands.txt in the RR folder.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
