Danielkh.. I was asking because I use my verizon Phone for a network connection using a Dial Up Network. Problem is, to connect it I have to minimize the skin and double click a shortcut on the desktop. Then I can hit connect or disconnect. I have been looking for a way to just have a button that can connect and disconnect in the skin. I was curiosu if maybe it was a half solution for this. Thanks
Here's the program if you want to play around with it.....
http://www.vzam.net/
My opinion is my own.
Well it is my voice phone too so it is not always plugged in. Maybe if I could get it to Auto Connect upon pluging it in, that would be great.
Possibility???
I found a Program Called " ReConnect 1.0". It has some small options. The main think is it is a stand alone exe. program. I unzipped and ran it, and it already had my pre setup connection that windows DUN manager uses. I hit connect and it worked!
John: Could this work for what we discussed?
ReConnect 1.0.zip
Yes VZAccess is for Verizon connection. I don't always have my card in so it was a way for me to connect and disconnect manually. I use the card on several computers. I have found that I usually don't need to use the program manually, just haven't had the time to retask the button.
The OBD diagnostics is just the program popping up on a blank screen in the skin. It already has pretty good finger buttons so I didn't try to reengineer it. It takes over the whole screen, so I only have a menu button on the skin, to re-navigate to the main menus, after closing the OBD program. I do not have an OBD interface yet, just preparing. It is the software with the best looking screens that I have found, but don't know the functionality yet. Here is the website.
http://www.obd-diag.de/
Wow! Thanks a lot. Im more of a hardware guy myself so skinning is so foreign to me. Could explain to me just how I would implement this? Creating the button, how that button actually opens this program etc...well really everything hod to get it to work?? It would be most appreciated.
Thanks again you really explained it well! I finially got them to work! Thanks so much for taking the time to help me out. Have a great day.
Phil
I am having a crash problem every now and then. I believe it to be a DFX problem. Here is what happens. When I start my car, my power controller starts my carpc. The computer boots fine, then the DXF 3.0 boot screen comes up. Then instead of the main skin screen, I get a black background with the Winamp consol at the top left, and a pink sqaure to the right of it. The music dose not play, just silence. I have to close it thru the task bar, as I can't control anything. Has anyone had this problem? Any ideas of what may be causing this? Yes I can fix it by reloading RR and DXF3.0, but that is getting old. I am looking for a real fix???![]()
In the Exectbl.ini under: Dynamic Menu Buttons, add:
"MyApp51","Load;Obdiag.skin;obd-diag;C:\Program Files\OBD-DIAG\OBD-DIAG.exe";OBD-DIAG"
Under: Pre-setup the Applications and labels into arrays, add:
<<MyApp51<<
Under: This is the label that is displayed on the Main Menu Buttons add:
<<=OBD-DIAG<< These will be self explanatory once you open Exectbl.ini .
Under :/ These are the labels for the application that will show
/ up on the screen that gives the selection of buttons to choose from, add:
"SetCommandLabels51","SETVAR;MyApp51LB;Obdiag||Set CommandLabels52"
In C:\Program Files\Road Runner\skins\DigitalFX 3.0\MenuIcons add the enclosed .png for the menu Icon.
And in C:\Program Files\Road Runner\skins\DigitalFX 3.0 add the enclosed Obd Diag Skin, and Obd diag on and off pngs. The skin opens with a full OBD screen and once you close the OBD program with its own exit function there is a menu button to navigate back to the DFX menu.
Obviously you need to download ad install the OBD Diag program also.
Also note that myapp 51 and setcommandlabels51 etc are based on where this landed in my programs. Your numbering might be different.
I think I got everything.
