Did you checked the Box in visual?
Show Guidance Screen during instructions. It has to be checked.
MGD. I tried
SETVOL;Line In;40
SETVOL;Line In;255
in Navicon2 and no reduction in xm audio when IG4 speaks.
Anything else that you can think of? Thanks
I checked the box. I didn't get SetVol;Line In;0 to work but I did get Pause/Resume and XmMute to work but there was a several second delay before the sound muted. I wish I could get the Line In command to work. About ready to give up for today.
I am a little bit stuck with setting up speedfan. I ran showspeedfan program supplied with the skin, but all I got was the following values:
SFT0
SFT2
SFT4
SFT6
Each of those values have a temp reading after it. I cannot figure out where to put these SFT# values in the skin so that it represnts the proper value. I see where there are other SFT# values in the code, but I don't know which is which. Can someone give me a hint on where to put them? thanks!
You have to download "Speedfan" for free. Get it here
Run the speedfan you downloaded. Then run the utility provided in the help folder. Also, in the HELP folder is a HELP file. In there it tells you the rest. Actually it tells you all of it, so just use that... You compare the temps between Speedfan and the one giving you the "SFT" values and figure which ones are which. Then when you have the two you want to use you put them in your Menu and menu skin files.
IE
L,246,444,303,21,#DFX1R#,#DFX1G#,#DFX1B#,15,"Arial :B","DATE","CENTER"
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial",[HL]"SFT2","C2F"[/HL]
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial",[HL]"SFT0","C2F[/HL]"
L,0,0,0,0,#DFX1R#,#DFX1G#,#DFX1B#,0,"Arial","GPSSP D","CENTER"
Yave to do it Menu and Menu2 skin files, it's right at the top.
Where I have the highlighted areas it will originally say "TEMP1"," LEFT or TEMP2"," LEFT
You ditch the LEFT, the C2F is for Fahrenheit. If you prefer Celsius don't add it.
Sorry for the large image below.... (My screen res is 1920 x 1080)
I was adding Google AdSense to my site to try to generate a couple dollars... a man has to eat.... er.... drink rather
Getting it set up, this is one of the first ad's I saw on my Road Runner Skin page!
I HAD to post this!Talk about misplaced marketing!!! LOL!!!!!!!!!!!
They must be doing pretty good to advertise with Google Adsense!
Please feel free to go to the site at any time and click the Centrafuse link, or any others that you want
My Fiero Build Thread
