Thread: DigitalFX 4.0
  1. #1681
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    LOL Dougw133
    John, The Install changed my fonts also, although I believe it just made them "bold".
    You are right that is what it did.... I like it though!
  2. #1682
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    After a failed attempt of building the database and restart of RR:
    After clearing that error:
    If you cant DODGE em, RAM em.
  3. #1683
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    There is a new version for download on the site.... Sorry for those that downloaded it already, but as it is early in the release, just packaged up the whole thing again.
    Just Re-Download, and install over the the current DigitalFX that's there
    It fixes problem with:
    - Should fix you guys's fonts all back to normal
    - Video not showing when the brightness overlay was on
    - Fixed missing label on the weather details skin
    - removed the brightness selector from the color chooser, as 2 windows were fighting with each other, the brightness is available as a selection for the main menu buttons.
    - iList on and off has been added where the brightness control was in the color changer screen. When changing, will drop you back a screen with a list in it to test it.
    My Fiero Build Thread
  4. #1684
    Nov 2007
    PA
    Should we uninstall and reinstall or just install over it?
  5. #1685
    Nov 2007
    PA
    I hope I;m not way off beat here or going to get yelled at because it's covered somewhere else.
    GPS Weather, working yet, did I miss something?
    GPS location, City State, County etc... Not working for me
  6. #1686
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Installed, everything working for the most part. I'm absolutely stunned, by far one of the best skins ever crafted. The best part about this skin is that you can install the default skin into any car PC, hit a few buttons and the skin then becomes modified to suit the vehicle.
    Awesome work John + Blue, with DFX and RRmedia, and many thanks!!!
  7. #1687
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Dougw133 View Post
    GPS has been working since version 2.0. You need to have a zips.dat file in your Road Runner root directory. (The skin installer installs it if it does not exist already) if that is in place, and you have a GPS signal, as well as RR configured for a GPS port (If you show satellites connected in the gauges screen), then tap the top display area on the gauges screen. The entire area is a hot spot to test the zips.dat LOCATE feature. If the cities and such fill with information, then it is working. You just need to add:
    localdatacaptureinterval=1
    To the RR.ini to update the information automatically. The "1" above means it will update the city labels every 1 minute.
  8. #1688
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by blk02si View Post
    Thank you, it is nice to see some positive feedback mixed in with all the this and that does not work
    Btw, another nice feature now, is when you "hit a few buttons and the skin then becomes modified to suit the vehicle" you can save all the settings in the Users screen, so when someone messes with it, one click and you are back to normal
  9. #1689
    Feb 2008
    Quote Originally Posted by rsrblade View Post
    No issues loading the db. Loaded 834 songs in 3min 43 sec. Only issue so far is on the gauges, the cpu jumps from ~8% to 100% then back down to and holds at 78%. I currently have this installed on a desktop with no gps receiver attached. That could be the cause of increased cpu usage as it may be searching for the receiver. I'll update once I install in vehicle.
    Okay, finished installing in vehicle. The database feature is wonderful. Really improves the performance and seek time. Excellent job John and Blue. Only issue at all is using the gauges still cranks the cpu, but that's the nature of flash.
  10. #1690
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    installed. works wonderfully. just a few cosmetic issues that i could fix myself...
    check all your screens for their online indicators in the top left. some have doubles, some have the word indicator, some have the icon, etc... its just not consistent. thats the only complaint i got so far!
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
