Thread: DigitalFX 4.0
  1. #1701
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by x10 View Post
    Anyone else add more than 8726 songs???
    I'm over 10,500 and it works fine.
  2. #1702
    x10
    x10 is offline
    Constant Bitrate x10's Avatar
    Mar 2004
    Pittsburgh, PA
    Hmm...its weird that it keeps crapping out at 8726....The total amount that RRMedia is trying to scan is over 13,000...any ideas on what to do?
  3. #1703
  4. #1704
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    First off, great skin! Thanks for all the hard work you all put into this!
    Now, a problem. Why in the music browser, when I click on a song, it wont play. I have to press the 'Play Select' for it to work. Also, the next and prev tracks dont work. It plays one song and then stops.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  5. #1705
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    John you've out done yourself yet again. Great Job. And the Database is sweet (props to you Blue). However my Db scan doesnt finish and i keep getting this Autoit error. Been at this all day and cant seem to squash this bug. Any suggestions?
    If you cant DODGE em, RAM em.
  6. #1706
    Jun 2002
    Virginia
    Quote Originally Posted by Machinehead View Post
    I'm at 28,000 and the database completed in about 5 minutes.
  7. #1707
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    GPS has been working since version 2.0. You need to have a zips.dat file in your Road Runner root directory. (The skin installer installs it if it does not exist already) if that is in place, and you have a GPS signal, as well as RR configured for a GPS port (If you show satellites connected in the gauges screen), then tap the top display area on the gauges screen. The entire area is a hot spot to test the zips.dat LOCATE feature. If the cities and such fill with information, then it is working. You just need to add:
    localdatacaptureinterval=1
    To the RR.ini to update the information automatically. The "1" above means it will update the city labels every 1 minute.
    Thanks, I got confused remembering the age old issue with Ziplocater.dll. I will be sure to check/correct those suggestions.. The skin kicks a%#. I might be getting a new mobo and processor to handle it though
  8. #1708
    x10
    x10 is offline
    Mar 2004
    Pittsburgh, PA
    Quote Originally Posted by kbreeden View Post
    damn.....well actually that makes me feel better...now I just have to figure out which file 8726 is....anyone know of a way to view some sort of log of the music -> SQL DB process?
  9. #1709
    Jun 2007
    Show off
  10. #1710
    Jun 2007
    Quote Originally Posted by PontiacGA View Post
    Sounds like you only have 1 song in your play list.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
