Thread: DigitalFX 4.0
  1. #1711
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Hello DFX 4 users...
    I have 9.2k songs on my DT and John has like 29K showing RRMedia has no limits meaning, there is a bug or issue with something in your music collection. I would assume that you mean when you hit xx songs that you are talking about the builder screen.
    I would like to get anyone having problems with the new RRMedia to more precise about any issues they like what you were doing when the issue occured and what the messages on any msgbox's you get as this will greatly help to narrow the problem area down as going througth 4,000 lines and locationing where the problem might lie a tad bit difficult and hopefully get it fixed quicker.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #1712
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by x10 View Post
    damn.....well actually that makes me feel better...now I just have to figure out which file 8726 is....anyone know of a way to view some sort of log of the music -> SQL DB process?
    BlueZX3 made a small program to do just that, run this program in your MP3 root folder, (where the RRMediaDB.db database file is located) In a few seconds you will see a Record Paths in db.txt file. Open this, and have a look at the last couple of songs. It may be some strange character in the tags, or in the file name causing it. A lot of logic is put into the script to filter out strange things, but there is no way to know every character in every language that could potentially cause problems. If it can be identified, it can either be fixed with the file, or with the database builder.
    As for all the other bugs and suggestions above, I have copied them to a text file and will adress each one of them.
    Attached Files Attached Files
    My Fiero Build Thread
  3. #1713
    Jun 2002
    Virginia
    John,
    Really, really nice work. I was a little worried about the font changes, but I love the way it looks. The database feature is a huge improvement. You're right that it performs like greased lightning. I like the way it saves the search results as a playlist that can then be loaded.
    I haven't been able to play with it as much as I would like, but so far it seems very stable. One issue I'm having is that I can't get anything to show up in the logo portion of the menus. Regardless of what I do it stays blank. Changing the menu layout has no effect. It worked fine for me in 3.0.
    I haven't been able to figure out how to use some of the new features yet, foremost among them being the disk changer. Hopefully, that will become clear once you post the video. I'm also having a heck of a time finding the gamma slider.
    Thanks again for all the hard work. A donation is on the way.
  4. #1714
    Jun 2002
    Virginia
    Quote Originally Posted by kbreeden View Post
    Aha, I see that I have to set up a button for brightness and then it appears when I hit the button. Nice.
  5. #1715
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by Machinehead View Post
    Sounds like you only have 1 song in your play list.
    But I'm not doing anything different than I did in 3.0.....and 3.0 still works fine.
    BTW, I dont want to use the play list. I just want to play the MP3's like theres a CD in the drive, from song to song.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  6. #1716
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    John,
    ...One issue I'm having is that I can't get anything to show up in the logo portion of the menus. Regardless of what I do it stays blank. Changing the menu layout has no effect. It worked fine for me in 3.0.
    Edit: Installed correct version like the instructions said and logos work fine. Sorry!
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  7. #1717
    Jun 2002
    Virginia
    Quote Originally Posted by PontiacGA View Post
    Now, a problem. Why in the music browser, when I click on a song, it wont play. I have to press the 'Play Select' for it to work. Also, the next and prev tracks dont work. It plays one song and then stops.
    Are you sure you're not confusing the search results screen with the playlist screen? The songs that show up on the screen when you do a search will not play like the songs in the playlist. You can only play one song at a time from that list and the buttons at the bottom don't work the way they do in a normal playlist. If you want to play all of the songs that appear in the search results, you need to go to manage playlists and load the playlist that says [searchresults].
  8. #1718
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    MP3art plug-in is not working. I've turned it on via the plug-in manager. Running 5-27-08 version of RoadRunner.
    Thanks,
    Jarred
  9. #1719
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    For those that have made a donations towards the RRMedia plugin thanks...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #1720
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Exclamation Donations:
    I appreciate the donations that some of you have sent, and I thank you immensely.
    I do ask that you guys keep in mind that all of the Media Database was coded by BlueZX3. He has spent 9 months coding just about every single day, for thousands of hours to bring this ability to Road Runner, and to the DigitalFX skin. He has also helped to 100% incorporate the database into the skin, as well as helping with the gamma slider, and created the ability to change the colors on the progress sliders. Needless to say, he has helped with so much stuff, its hard to remember it all
    So if you consider donating for the work in this skin, I ask that you take that donation, cut it in half, and give the other half to blue. It's only fair.
    Or if you are in a really good mood, just don't split the donation in half at all, and just donate that amount to both of us! LOL! (Just kidding of course!)
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
