As another data point in the database building:
18626 songs in 16:21. No glitches. Beautiful work!
Funny you should mention that, Blue, because as soon as I hit the post button I thought that I should have mentioned that a donation would be coming your way as well. Then I thought I remembered that you have your own donation button on your media database thread and figured I would just go there. You have become an indispensable member of this forum and your efforts need to be rewarded. Accordingly, donation coming.
I took the work of the person that fixed the sat skins for DFX 3 and tweaked the DFX 4 files. Sat and Ter bars work like a charm now.
My Fiero Build Thread
Ok...
Having HD Radio issues. I got my HD working and was perturbed how when I switched from HD radio back to MP3, the plaer was at volume of 0. Did some research and found "Mitch's" RR patch and HD radio updates. Installed accordingly and eplaced the RR.exe with his. It works a little better with HD radio however the Slider bar at the bottom is back to the old format and my Center logo was gone. Switched back to my backed up "Weather Fixed" RR and those problems resolved, but now the HD Radio doesn't work.![]()
Oh also, my album art now flashes at start of song then disappears. I have tried everything and never had this issue before... I'll keep hacking away I'm sure it's on my end.
Just for the record, everything, (and I mean EVERYTHING) was broken when I installed DFX4 to a non standard path. After I installed it to the default (c:/program files/Road Runner) everything worked great. It sucks that its hard coded to only run from the default directory, but when its there it runs good. I had many of the similar problems mentioned when I was trying to run it from C:/Devel/RR which is where I like to have my RR install.
Any body know where the "shuffle/repeat" button is?
