Right! RRmedia![]()
Seeing that i do now have several apps that i manage, which app are you refering too? RRMedia? DFX Button Editor?
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Right! RRmedia![]()
If you cant DODGE em, RAM em.
Ok..Really not trying to beat a dead horse but I think I might anyways.
Any one else here using HD radio?
If so what RR.exe are you using? (MJS, Weather Fixed etc..)
Any problems you ran into?
im using HD Radio with DFX4.0 and it works like a charm.
my version of RR is the newest... and i haven't applied any of the patches (weather, mitch's version, etc.)
did you place all the files from mitch into the HD Radio folder and run the runme1st.bat file?
I don't know if it has to do with the data base builder or with some other unrelated function, but When I hit choose album and hit play, the first song of an album, shows the last song played. Then when it gets to the second song, it is corrected. Also a lot of times the album title is not shown. This is in the main menu screen. I had no problems with DFX3
I did try the patches but it requires you to use his RR version which is older and doesn;t work for weather.. I can't get it to work either way now though.im using HD Radio with DFX4.0 and it works like a charm.
John,
Once again the skin kicks ***. I am having some issues. One is that when I try to go to hibernation on DFX 3 & 4 it freezes. It happens alot. Is it the CPU being overloaded?
Second issue happened after I installed DFX 4. When I rebooted after installed it show huge number across the exit, play, rw,fw, and volume controls at the bottom. It is now happening in DFX 3 too! Do you know why it is doing this?
Alright...HD radio working...After much exchanging of files and some pure luck. I am using the RR beta weather fixed. Still trying to figure out how stop it from lowering master vol to 0 when exit HD radio going back to music.
My Album art display fixed on the reinstall (must have messed something up myself)
BlueZx3- I built the data base and those errors never happened again.
I am having issues with CPU and performance as I stated earlier. I did a lot of re vamping and my skin idle Cpu is around 10%. It's when I switch screens it jumps to 100.
Has to be a hardware problem on my end.
I noticed one other thing. It seems iGuidance loads smoother, kind of a fade in. When you toggle the layout to something other than default, and then hit menu to return to main skin menu it de-toggles it first. So you have to hit menu twice..
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
