Thread: DigitalFX 4.0
  1. #1791
    Apr 2008
    Hagerstown, MD
    So the best view I have found with this skin using the garmin software is when you go to music and hit gps. Is there a way that I can make a garmin button that will automatically open like this. I'm pretty sad a garmin button wasn't integrated in this version 8^(
  2. #1792
    Jul 2006
    John,I posted this earlier, but I think it got lost in the flood of questions LOL!
    I run in 640x480. That doesn't seem to play nice with some of the new stuff, For instance, the color chooser won't pick colors along the top row. There are also visual side effects like certain menus not lining up right. I think these are executed by an external script? I assume the menu offsets are defined somewhere in their respective scripts? Is there an easy solution, or do I need to run 800x600?
  3. #1793
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    The reason that you are having problems lies in the fact the 4.0 now fully uses my RRMedia plugin to manage the audio media. And yes it is a bit different than the old way of how the old browser worked. And going by what you posted to me, sounds like you do not like change of any sort, good or bad. This is also v1.0 of my plugin and many things to be added and tweaked to make it as user friendly as possible, its just not quite where you want it to be like at current release.
    You should never assume what someone likes or does not like, and why would someone like a bad change, as you said. I love change, but why change something that worked perfect? Dont you ever want to listen to a whole album? Why make a playlist when you can just click on the song and let the whole album play? I CANT be the only one out there! I'll keep an eye on your program.
    The simple solution to your problem would have been to p&h the browser button and then selected to use the old (now outdated) audio_browser method of playing your tunes. Once selected it saves you choice and always uses that for the browser button cmd
    I actually did try that and nothing happened. I just tried it again and it worked. It may have been where a clicked on it the first time. Thanks.
    Hey Mitch. You gonna make a new version of your version of RR so I can have my happy, bouncing Pontiac girl flash back? I'd prefer not to switch off of your RR since it works perfect with the HD, etc.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #1794
    Oct 2007
    John, Blue and whomever else contributed to this skin THANK YOU its AMAZING.
    Has anyone been able to get the "Garmin GPS" screen to work when I click the button nothing loads.. Do i need to set the GPS to external application in the config similar to iGuidance? If so does anyone know what the "window name" should be..
    I have not tried the RRMedia yet but plan on doing so very soon!
  5. #1795
    Apr 2008
    Hagerstown, MD
    Quote Originally Posted by RanDJ8487 View Post
    oops I must have missed it. I see the button. Not working tho
  6. #1796
    Apr 2008
    Hagerstown, MD
    Okay I used the button editor. Here I changed the path to my que.exe file. Seems to come up fine. I dont have the real version of garmin on this PC so I'll have to try it in the car or someone else can give it a shot. It was embedding for me fine on here but I was unable to hit 'menu' when it was running. Give it a shot and keep me updated!
  7. #1797
    Low Bitrate overlander's Avatar
    Feb 2008
    Quote Originally Posted by swj123 View Post
    Did anyone figure this one out?
    I got this same error after I ran the music db initial function. Now it is persisting. it actuall first happened during the initial music db build on the "import playlist" function, which is perpetually stuck at 0%. trying the "rebuild" function, but it is still stuck right there at the initial build part.
    only other issue I ran into, was after initial install, RR booted dfx4.0 with a white background, and I could only see 1 or 2 buttons on any screen. I had to go from 3.0 memory, and start tapping where I think a button would be, for it to show up with black background. after I found digitalfx settings, I was able to change to a different color screen, and then I could finally see everything enough to navigate.
    The rest of the skin is fantastic. love the new iguidance smooth transition, and the new icons and feature sharpness are excellent. weather works great.
  8. #1798
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by barnyard View Post
    Sorry,
    I anderstant very bad english
    If your question i how work on 640x480, modifier the general.ini file in the screen
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800 --> 640
    ShowHeight=600 --> 480
    By
  9. #1799
    Jul 2006
    Quote Originally Posted by pierrotm777 View Post
    Sorry,
    OriginalWidth=800
    OriginalHeight=600
    By
    Yes, I did that. The problem is that menus executed by an external script aren't lined up correctly
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  10. #1800
    Oct 2007
    Quote Originally Posted by dmistry View Post
    Oh it looks like the default path is set to I:\ I will change it to C:\ and see if that works.
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
