Another thing I noticed is that the "YouTube" button does not seem to be working in the RR Command in the DFX button editor show's "YT" should this actually contain something about loading the skin type thing?
How should CDRip be setup? I have the files, and installed the CDRip folder in the absence of information in the windows program folder \programs\cdrip, but the "rip cd" button doesn't work in 3.0 or 4.0 for me. any tips?
John,
One more thing I am not sure if this is me being stupid but it seems like the DFX4 package does not have the backgrounds folder and related images.. so if you do a fresh install of DFX4 it breaks until you create a backgrounds folder..
I did reinstall DFX4 and same thing no backgrounds folder it worked when I just installed DFX4 with DFX3 installed because the RRConfig.exe had the backgrounds folder pointing to the DFX3 locatation but as soon as I uninstalled DFX3 it broke the skin until i did the above mentioned.
Now that RR has the transparent(GDI+) avail, some people are now using a backgrounds folder in the RR folder that way any skin you have installed and is of a traspartent type can all use backgrounds from the same folder...
John being one of them and decied that with this version(4.0) that the background folder should now be placed in rr root folder..
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Doh thanks Blue.
I just recall 100's of posts from people bi**** that DFX had a vertical line and the fix was to correctly set the backgrounds path to the skins/SKIN/backgrounds. May be this should just be added to the help file or something *shrug*
ok, I could swear I've seen this posted before but I've not come across anything in the search. I'm trying to use the dfx button editor with dfx4 and all I get is an error :
Line -1:
Error: Array Variable has incorrect number of subscripts or subscript dimension range exceeded.
I put it in the dfx skin folder, is there something else I'm missing? I made a backup of the exectbl.ini
