Thread: DigitalFX 4.0
  1. #1831
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    I've got the same screen as this guy with all the numbers showing on the bottom instead of icons
    Also, the biggest problem is only the music button works and all the other buttons on the main menu are dead(no response)
    I'm using the latest RR with digitalfx 4.0. I also installed the latest flash. What could be the problem?
  2. #1832
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Fonts
  3. #1833
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Ramanator View Post
    Blue, Do you know if the guys with this error, error out at the same spot?
    Would you check your playlistpath in your rr.ini and post weather it has a trailing backslash? Willing to bet that it doesn't have one...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #1834
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Here's mine:
    playlistpath=C:\Documents and Settings\My Documents\My Music\
    If you cant DODGE em, RAM em.
  5. #1835
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    well that deserves a ....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #1836
    Feb 2007
    Motor City
    How much did u say the bet was
  7. #1837
    Nov 2007
    PA
    One more: Movie times is finiky and managed to crash RR twice. Also the pad to enter zip code, the zero is in the middle.
  8. #1838
    Nov 2007
    PA
    I cannot get the interactive weather to zone over my location. I changed the Lat and Long in my skin file and It is still hover over Kansas? Also can the traffic map be changed too? Thanks.
  9. #1839
    Jul 2006
    Quote Originally Posted by JohnWPB View Post
    I am working on the color chooser now, and will have it all fixed up. Can you tell me exactly what menu's are not lining up? RR is supposed to scale and locate the pop-up menu's depending on the current resolution.
    The overlay image (see screenshot) is shifted to the right and about 25% too big. If I try to choose a color in about the top ¼” of colors, then choose to set one of the attributes to the color, it changes to the color of the button that you click on.
    RM_Browse_Mode.skin was also offset, but I fixed this by changing the POSX to 120.
    I haven’t come across anything else yet, but I’ll let you know if I do.
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  10. #1840
    Jun 2002
    Virginia
    Quote Originally Posted by qha_vn View Post
    do you have minimum system requirements to use your great DigitalFX? my pc seems not strong enough to host this skin. on my pc, it can not load the skin fully, buttons just appear when i hoover the mouse pointer over them
    by the way, i use single pc board with 512MB RAM, 1GHz VIA Eden processor
    I had a similar issue yesterday when I tried to load the FX 3.0 skin. Everything was grayed out until I ran the cursor over it. I don't know what the cause was, but I don't think it was lack of computer power. Have you tried reinstalling the skin and maybe even Road Runner?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
