My system does not work this way. Is there some setting that needs to be activated for this to work? When I hit play select after doing a searck for say 'pink floyd', only the highlighted song will play. Same as with the whole list. If the whole music library is displayed and i hit play select, only the highlited selection will play. I cannot select all and play select.
You're not talking about the same thing. In John's case he's listing his music by artist and then hitting 'play selected' which will load all the music sorted under that artist. In your case you're picking a specific song within a search result, and that will only load that song.
Machinehead is correct. The search results screen and the browser screen are two different things and work differently. In the browser screen you can browse through genres, artists, folders, etc. and when you find one you want to play you hit play select and the artist, album, folder, etc will be loaded into a new playlist.
If instead of browsing you want to search for an artist, album, etc. you hit search and that will display your search results. Your search results are not a playlist and can only be played one at a time. In order to play your search results you need to hit manage playlist and then load the playlist that says [searchresults]. Now your search results are in a playlist that you can use like any other playlist.
Is anyone else having a problem with the short cuts in the GPS section? When I select it to find the nearest gas station it has and error. It didn't do this in DigitalFX 3.
The reason that this was done this way is because when you do a search, you might be only looking for one song and if you end up with a large results list you can just skim through and just play the song you were looking for. On the other hand you can also search for all songs by an artist, ect.. then just just load that results playlist, or better yet if you search for an 'Hip-Hop' genre you can make a Hip-hop disk. Other reason being that there was no more room for any more buttons, as John has told me a-many times...![]()
I do realize that this does work a bit different than the typical user might expect and to be expected with such powerful features at your fingertips, but once you get the hang of it, you should start to see how versital it is to use..
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
