If using the folder browsing mode, do you have .flac in your audio type settings in the config?
As for FLAC files, blue, it still won't work. If I play a FLAC in winamp stand alone and, then open RR it will show the info. But if I seek it out within the skin/rr, the folder is there but the files do not list.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
hmm....Good call. Let me check, girl has the car. Willing to bet that would be the case..
Wow, when did full screen viz start working? I just tried it and it worked great, other than the fact that it was a little off center which can probably be adjusted in Winamp. It's probably something that has been working for a year now and I just missed it.
Also, I really like being able to include the current playlist on the menu screens. Good thinking, John.
should the button editor be working in 4.0? Won't run for me. errors out.
Also, I can't get cdrip to work, despite following all help files. the new exectbl.ini file is very different now. anybody know how to modify it to get cdrip to work?
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Okay tried everything. I've even uninstalled all DFX installs, uninstalled RR. Deleted the RR folder with the exception of rr.ini. A lot of problems have fixed bc I only installed 2.5 and 3.0 but theres some sort of auto run feature still causing problems. Any ideas? I have not yet set the one file to recognize which was my CD drive. Thanks![]()
Yes I got the NumOsk problem, it an all other bugs mentioned up to this post have been fixed, or are in the process of being fixed.
As for Google Traffic, The GPS location was not completed when I release it. It will be for the next version.
I do not see how this is possible. It will go back to whatever screen you were on before. The command on the Menu button on that skin, just sends you back to the skin you came from.
If the Visu is a little off center, this is usually indication that Winamp 5.13 is not being used, but another version. Strange as it may be, the only recent version of Winamp, that the visu shows up to where it is supposed to, is 5.13. Any other version, and the visu will appear over and down about 100 pixels each. Though all features with other versions work ok, and the visu works with other versions, it just will not show up where it is defined.
My Fiero Build Thread
(Asked further up, but I think it got lost as part of another post)
John, how hard do you think it would be to create another Menu layout option, where the center graphic gets replaced by the currently playing album art? Something you've considered? Working on...?![]()
