You have to first choose the correct menu layout.
Printable View
Speedometer seems to be showing the wrong speed, how do i change THE KPH or MPH IN DFX 4.0
I have chosen the correct menu layout and still nothing displays. I have tried every menu layout and still getting just a black backgroud wherer the image/flash should be
I have tried to install DFX4 on my Moms computer and the flash, clocks and icons work fine, but on my computer they dont work in v4, but v3 is fine. This is weird
Be sure you are running the latest beta RR version. You can find it at the top of the Roadrunner forum in the stickies. I believe it is version 5/27/08
reinstall latest RR and DFX4? i would try that because it seems to fix a lot of issues
Edit: :whs:
I am actually using Mitchjs version of roadrunner right now which is build of a earlier version on RR. I think its v 11/02/07 as this is the only source available. THe weird thing is if i can get it to work on the DFX3, why not 4.. I will revert back to the newest RR to see if there is any difference.
From the main menu > music > browser - only the "sel" button work. Is it only me?
yes, your right. Unless you click in the window then the up and down arrows work, well sometimes.
Could someone point me in the right direction regarding the weather? It's probably something stupid, but I can't get it to work. :)
I dropped in the 2 files from 05/27/08, which i believe was the weather fix.
I am connected to the web.
GPS antenna is working fine, I know because the speedo, etc work great.
I put in my town and state in the config.
The weather screen opens, and I can load the most recent Sat, Temp and Radar maps dated today.
The problem is I cannot get the 1 day and 5 day views to display anything. No images, no temp, forecast, humidity, nuthin'. Those 2 screens just have the labels, but no info that goes with them.
What am I doing wrong? I thought the 2 files from 05/27 would fix that.
Also, is there any way for the AutoIt icons NOT to show up in the taskbar next to the clock? It seems like 4-5 are running, and becuase that section of the taskbar is so long, the open programs part of the taskbar can only show 2 open programs without those dopey up/down mini scroll buttons showing up.
TY in advance.
