Thread: DigitalFX 4.0
  1. #1921
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by ccwild View Post
    First off, thanks to John and Blue for a great skin and db application.
    Well I'm having the same problem as Stealth, the database builds but searching and browsing anything other than Folder view yields no results.
    I've tried everything including rebuilding the db and fixing all tags on the mp3s. When reduilding the db, I have a green checkmark on all things except for "Ratings Playlist Found" and "Ratings Playlists Imported".
    I know it's probably something simple I'm missing but I've been at this for 4 days now with no success.
    Some quick simple checks:
    #1 Size of your db file? (located in your musicpath root)
    #2 Take a look in at the FilesScanned.txt file to see if looks ok? (located in your rr\RMDatabase\Support Files folder)
    #3 Have a look at the 'Files Missing Tag Info.txt'. (located in your rr\RMDatabase folder)
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #1922
    Oct 2007
    ohh let me try that thanks!
  3. #1923
    Oct 2007
    Quote Originally Posted by Ramanator View Post
    Did you try the press and hold? Each button can be set individually.
    Ok this helped but it seems that the buttons are misaligned anyone else?
  4. #1924
    Newbie theforce's Avatar
    Jan 2007
    Ohio
    I have a problem with getting WinDVD8 to work. I managed to get WinDVD to start up but after the controls disappear when I try to bring back the controls by taping on the top left corner it focuses the WinDVD program to the top of the screen so RR is behind the WinDVD window. Is there anyway to get WinDVD8 to work with this skin? Or what is the best DVD software that works with this skin?
    Also what happened to the on screen keyboard in the browser skin? Is there anyway to bring that back?
  5. #1925
    Apr 2008
    cant get this to install with vista hangs at 22% fix flash any ideas
  6. #1926
    Oct 2007
    Quote Originally Posted by hollow View Post
    Use XP
  7. #1927
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I had the same problem on XP SP3. So it is not a Vista problem.
  8. #1928
    Oct 2007
    Quote Originally Posted by MGD View Post
    Interesting I am running XP Pro SP3 and I did not seem to have a problem
  9. #1929
    Oct 2007
    Quote Originally Posted by JohnWPB View Post
    Ok, after pulling my hair out, as well as Nitr8, The bug tracker appears to be fixed YEA!
    For those that already registered, I had to copy your bug reports, thus they are under my name... sorry. Also anyone that registered, you will have to re-register... sorry again.
    It's very simple. User name, Password, Real Name (USE YOUR FORUM NAME FOR THE REAL NAME field), and email address. (You can use a fake email address if you want).
    Let's try to keep ONLY bugs posted in the bug reports manager. For instance, Hoe do I get the 3D logo to show up in the menu, is NOT a bug (And will be marked as such in the bug tracker )
    If you look through just the last 10 posts alone, you can see why this bug tracking manager is really essential to keep on top of things! Everything can get buried and over looked REAL fast in this thread, as most of you already well know
    Thanks again, and I really appreciate the help in posting bugs there.
    If you need to post a screen capture to go with your bug report, Just upload it to http://imageshack.us/ or any other photo sharing service, and post the link to the image in your bug report.
    If you post a bug, check back within 24 hours to see the status, as well as any comments, or if further information is needed. You can see if any comments have been posted by looking at the number of comments in the comments column. (Looks like a yellow baloon at the top of the column : )
    The link to the bug manager is under the download link for DFx 4 on JohnWPB.com. And do feel free to check out some of the sponsors on the site
    I am still having issues I have registered like 3 accounts and I can not seem to be able to contribute to the bugs/comments am I doing something wrong?
    Never Mind I got in
  10. #1930
    Newbie ccwild's Avatar
    Apr 2008
    Middle GA
    1. 29KB after I rescanned again. it was around 500K
    2. I can't find this file...... It's not in the folder specified
    3. There are quite a few files that are missing some parts of the tag, but all of my files have some parts of the tag. Do all fields of the tag on every song have to be filled in for the database to work?
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
