You have to find what file(s) in your music folder that causing the problem...
I had the same issue solved it by removing a character in the artist name...
Went from having a 250 kb to a 7148 Kb in my musicpath root
It should work..
Learning something new about this version every day. Great!![]()
It should work..
How do you open a new task over there at the bug-tracker?
Ummm click on the "add NEW TASK" button at the top*You have to register to see the button)
Stepping AWAY from the computer tonight
Going to see Journet, Heart and Cheap Trick in concert..... Gonna seem strange with the new Journey lead singer Arnel Pineda. It's SCARY Just how much he sounds exactly like Steve Perry....
My Fiero Build Thread
#1 Any time the db is 29k that means that its an empty db as that is what it is before anything gets imported.
#2 This file most likely is missing because of the recan, it get created on the initial scan and on rescans gets replaced with the recanned file paths when the recanning is finished.
#3 No, one does not need to have all of the tags filled in.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I would like to know what character was removed also.
Oh well, I guess I'll get started searching for the rogue file. I've already searched through my 11,000 song collection twice to find two files that were causing the database build to crash during my first db scan.
I do have some .flac, .ape, and wma files in my library, will these files cause a problem?
Also, do I need to create the ratings playlist ( 1 Star, 2 Star, etc.) or should they be created automatically by the program?
Holding ANY info on files that caused a bad/incomplete builds to your self, isn't going to help others that might also have similar files nor help me to see if I prevent them from crashing the building process...Originally Posted by ccwild
Current supported formats are 'MP3,MP2,MP1,M4A,WMA,FLAC,AAC,WAV,ASX,OGG'Originally Posted by ccwild
No, the only reason that I have these two steps in there are to automate the importing of the older rating system by Sonic into the db.Originally Posted by ccwild
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Yeah, un-A$$ the info or the......Holding ANY info on files that caused a bad/incomplete builds to your self, isn't going to help others that might also have similar files nor help me to see if I prevent them from crashing the building process...is on.
If you cant DODGE em, RAM em.
