Thread: DigitalFX 4.0
  1. #1991
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The other thing you could try is replace this skin file with the orig. The only thing different is I have copied the that cmd line and commented out the old one and then replaced the cmd that john was using for the play ablum to the RRMedia cmd that he didn't use and if your track tags are filled out, it will play the album in track order.
    [EDIT]
    skin file updated...
    Changed both the button below the pic and the hidden button over the pic, only did the hidden over pic one before...
    Attached Files Attached Files
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #1992
    Jun 2008
    Some problems whit DigitalFX 4.0
    Can some one help me..
    I cant get map Monkey to work whit this skin..
    I love the skin but i realy need map monkey..
    I have tried switcing the GPS button to Destinator bur then the screen just turns blank..
    Map monkey works whit other skins.
  3. #1993
    Mar 2008
    tried winamp still asks for opening file after "play this album" and hangs there, after cancel the request the playlist goes empty...
  4. #1994
    bmo
    bmo is offline
    Low Bitrate bmo's Avatar
    Feb 2005
    ohio
    Quote Originally Posted by blk02si View Post
    The band works for me, but as a work around you can go to direct tune and just enter 580 or any AM station and the HD tuner will auto switch bands.
    Nice.... never thought of that...
    Thank you much
    Bmo
  5. #1995
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by dimmu1975 View Post
    I don't think that you did as it still showed 0 views but i forgot about the other button, see my edited post above...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #1996
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Probably need to create the ratings folders:
    - My Music
    --Playlist
    ---1Star
    ---2Star
    ---3Star
    ---etc.
    Then define the path to the playlist folder in RRConfig.
    Just guessing.
  7. #1997
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Play this album has nothing to do with the ratings except that is on the rating screen.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #1998
    Variable Bitrate quantum's Avatar
    Sep 2005
    Quote Originally Posted by treetop777 View Post
    "-Added the ability for weather to be automatically updated based on you current gps location. This requires a new rr.ini option called localdatacaptureinterval. This chooses the interval in which to read the zips.dat file that gives us the city/state for weather/labels
    localdatacaptureinterval=0 (default) data isnt automatically captured
    localdatacaptureinterval=1 Data pulled every minute
    localdatacaptureinterval=2 Every 2 minutes
    localdatacaptureinterval=5 Every 5 minutes
    localdatacaptureinterval=10 Every 10 minutes
    localdatacaptureinterval=30 Every 30 minutes
    -Added the ability to display current city/county/state/zip as rr labels either manually with "LOCATE" command"
    In DFX, that whole area where the labels are has a hidden "locate" command - click it.
    TY Treetop, greatly appreciated, solved both problems.
    This was in the DFX Help file????
    I sure as hell didn't see it there, it isn't in the "How do I get the Weather to work" area for sure, and it isn't in the revsion history either...
  9. #1999
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    For those of you that may have noticed: The new GPS volume "thingy" pages are not right. Only "Windows Down Loud" (preset config 1) seems correct to have the correct backgroung png file show up.
    This is the work of INH first listed in post #1382
    I would suggest that you redownload the "thingy" files from here:
    http://stealthcrx.com/files/GPSvolume/GPS_Speed.zip
    Not my stuff, just trying to help correct a problem I noticed.
  10. #2000
    Mar 2008
    Ok I have posted this in the main road runner forum and I have done many searches and have found the problem on here but nobody telling a solution and I a posting it here because I want to use this skin with road runner so I need it working for this skin
    ok I am having a problem and if anybody can help me out I have the latest rr and mappoint 2006. In the rr config I have clicked on the radio for mappoint put the port number of my gps in the port box but on the default skin if i push gps nothing will happen at all and when I use digital fx skin the latest 4.0 one and change the button to be the mappoint button when i push it it will open as a window on top of rr so if I push any button with the digital fx skin nothing happens to mappoint what did I do wrong I have also uninstall mappoint and reinstalled it and still nothing
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
