After reinstalling Windows XP again still nothing, "play this album" still didnt work...
Am i the only one with this problem
What is the right order for installing RR and DFX4 on a fresh XP install? maybe i do something wrong here....
My Fiero Build Thread
A couple things come to mind....
Open the DFX skin fo;der, and the helper files sub folder. Double Click active winamp and install it.
Then try the play album, if it does not work, then:
Close Road Runner. Open WInamp stand alone. You will need to open the library window, and add your MP3 folder to the library.
This is to be replaced with code in the next release to use the RMMedia Database play album command.
John,
I have just a little gripe with your quotes here. Nothing major, and certainly nothing to get upset about, but fair is fair, and facts are facts, and quotes are quotes...
First off, I DID search and DID know about the weather being a problem back in April or May. I was also aware of the patch Guino created on 05/27. My issue was with something specific on the 1/5 day screens, not the weather screens in general.
Doug133 was kind enough to respond and ask which 2 files i was talking about and my reply was:
I tinkered around a little with the skin files, went back and read through the help files and then, since I thought my question may have got overlooked in the flurry of posts (understandable), I asked the question again. I also started to realize that the 2 "problems" I was having MIGHT be related, as posted below:
This is about when you had your snit and quoted all the questions, and hey, I can understand if you got a little frustrated, we've all been there.And, your apology was accepted at that point, no harm, no foul. I didn't even think twice about it.
Treetop777 posted this reply, which immediately solved the problem. As I said earlier, this was not in the help file you put together for DFX4.0, and if it is, I'd like to know where. It appears (near as I can tell) to be a RR Update. So, I was looking in the help files for something that had nothing to do with the skin, it was a RR Config setting (OK, I didn't even think it was RR, I thought it was something to do with the skin), my fault.
A big thank you for the fix went out to TreeTop777, that solved the problem. I went back to the DFX help file looking for this info, and it wasn't there. I can only assume it was a RR Config thing and probably in a different thread.
The solution you copied and pasted was not the answer to the specific problem I had. I already had the Sat and other maps working.
Based on some of the valid bug reports, i thought this may be a bug. It wasn't, ok fine. Maybe someone will come along one day, have a similar problem, find Treetop's response and solve it without asking a question.
That's what a forum is all about. I missed it cus I was searching in the wrong spot. My bad, 1000 apologies.
Many people have an area of expertise we can offer to the community. Your's is skinning, mine was the night vision project and maybe some fabrication from a been there, done that standpoint. We all contribute, we all benefit, the world keeps spinning, life goes on.
I am also of the belief that there is no such thing as a stupid question, but that is the teacher in me I suppose. In all fairness, I have seen some posts on here that are easily answered with a search.
And, when it gets a little frustrating, blowing off some steam can't hurt.
So, like I said, no hard feelings I hope. That is not my intention. I can certainly appreciate the hard work and many hours you put into this skin. Just wanted to set the record straight for these quotes and the quotes in the other thread you pasted them into.
Friends?![]()
Working on - 2006 Cadillac Escalade with all the TOYS!
COMPLETE! - 2002 Cadillac DTS - Summer 2008 - SOLD SUMMER 2010
COMPLETE! - 1998 Cadillac Deville Concours - Summer 2007 - SOLD SUMMER 2008
quantum, absolutely no hard feelings in any way at all. In fact another apology is on the way.
There was a question that I was answering with the quote above... I got the 2 mixed up, . I just remembered seeing this a couple times, then you saying you could not find it in the help file, and thought it was the same thing ... my bad
THIS is actually the question that I was answering above, when I quoted you as the poster hahah!
As for the locate command for the City Labels on the GPS Stats screen, I will definitely add that to the help file, as I could swear I had something in there already for it, but its certainly not there.Also, where do I find the Weather_Interactive.skin to modify it for my L&L? I did it for 3.0 and now it seems I have to do it again for 4.0, but I can't find the file
Could any one point me in the right direction pleas? The problem I'm facing is very simple:
In a minute or so after DFX 4 skin starts - RR gets frozen. I traced the problem to GPS USB devise. When I disconnect it - every thing is OK. Before you ask - yes I have latest RR installed and it works with DFX 3. If you could just give me an idea where to look...
I know, I could try to reinstall RR and DFX, but before I do it I want to try to fix it.
Thanks John, You're the man. I was even able to tinker with the cooridinates a bit (really confusing at first) to make the album art a little smaller as to give a sort of border effect.
I was even able to add a "previous avs" command button along with the "next avs" hidden button (side by side).
Now all I need to do is go into photoshop and create some sort of frame to outline the album art, sort of like the ring surronding the Ford emblem in the flash clock shown below:
Since I'm not to good at PhotoShop this may take a while but I'm up for the challenge. So if anyone has any recommendations please let me know...
And to all of the noobs like me, don't be afraid to get in there and tinker with things a little. just be sure to backup the default values just in case you screw something up.
I'm actually starting to learn a little bit![]()
This is exactly what happened to me when xport wasn't used correctly. if RR and Iguidance (or some other software) are both battling over the same com port, you will be frozen for sure for a while until the struggle times out. make sure in RR config your GPS com port is one of the splits, and that your nav software is the other split, and that neither RR or Inav are using the actual com port. If you don't have xport or another com port splitter, disable one of the softwares GPS function until you get it.
well... As I said it works when I switch back to DFX 3.0. I checked all the ports and they are set correctly. And I waited for long enough for it to unfreeze - no luck. Need to kill RR.
