@ccwild if you make your border and save as an png , stick it in your skin folder, and add an IMG, line to the txt file of your album art and call it IMG,x,x,x,x,"Artborder.png",OUT
this will then show the border only when you use ablum art theme.
Printable View
I don't use xport. I use GpsGate. But even with xport it is the same. My usb device is on port5 and then I split it to Com3 - IGuidance and Com4 - RR. I know com3 could be a problem, but I've tried 5 instead with the same result.
When it freezes, RR is taking up 50-60% of CPU. When on DFX 3 - there is no problem. As soon as I go to DFX 4 - it freezes. Drives me nutsbanghead
NO@!@!@!@!@ Hhahaha
I have multiple copies of the skin here, and just name the folders to keep track. I have one that I use with some alterations, one for my Home Automation, one that is the released, and one that has the fixes from the last release. This is how I intend on making the patch, by just packaging up the differences in the released, and the one I am doing the fixes on.
I have the same issue with my weather not showing any 1 or 5 day weather data or pics.[For my weather problem? BTW i am using ZX3's RR config utilityQuote:
RR Config > GPS Tab > Upper right hand corner drop down probably says 0. Change it to 1 or something other than 0, problem solved.
Or did you mean my WEATHER tab? The weather tab has refresh interval of 1 not zero and my GPS tab does not have a place that may relate to what you said with a ZERO value?
To anyone having build/recan problems...
I am currently in the process of switching the builder over to a vb app (currenty done in AI). I am currently more than half way and so far the testing that i have been able to do looks like this will now allow me to catch all errors and deal with them. Meaning, no more builder crashes durring a build/rescan...:whoo:
Just a thought. I never had to add "LOADCAPTUREINTERVAL" to my RR.ini, it was already there. Did this happen as part of the updated config blue?
Nope, its been there since sonic added it to RR.
If that is what you want to call it... AI wasn't allowing me to do that when there was an error with the cddxxx.dll loading a bad file, it just crashed the whole thing...Quote:
Originally Posted by nst6563
