Cool....
Printable View
Cool....
John -
Just wondering, where is the data from the maintenance screen stored? I had some things set in DFX3 that I want to just port over into DFX4, but I don't see any sort of maintenance.txt...? It looks like the skin file saves the variables...into itself?
The actual skin is probably exactly the same. No changes from 3 to 4. You should be able to just copy the maintenance skin from the DFX3 file to the DFX 4 file and all will be good.
Cool. So this is maybe a little OT, but aren't the .skin files basically just text? How can they "remember" variables (without altering the file itself)?
This is what you need to do,
#1 open up your "Skin.ini" in your 3.0 skin folder and copy out the millage stuff(~1/2 dn)
#2 open up your "skin.ini" in your 4.0 skin folder and replace that millage stuff copied from the other file save and you'll be good to go...
I do not know what could be causing that.... sorry. You do say that RR and the skin work fine if you unplug the USB GPS puck. This definitely is not a coding error then in the skin.... Hmmm
Try looking in your rr.ini, and in the skin.ini and find a line, if its in there localcaptureinterval and change it to 0
Then look in the RR Root folder for zips.dll, and if there delete it.
These are the only two things that I know of that are timed... The skin itself does not have any recurring timers.
