Thread: DigitalFX 4.0
  1. #2061
    Jul 2006
    Quote Originally Posted by spamminator View Post
    John -
    Just wondering, where is the data from the maintenance screen stored? I had some things set in DFX3 that I want to just port over into DFX4, but I don't see any sort of maintenance.txt...? It looks like the skin file saves the variables...into itself?
    It's in skin.ini
    oops! I missed a page of posts! Sorry
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  2. #2062
    Oct 2004
    St. Louis area
    John, I came across a simple problem.
    I went in to change the GPS speed volumes, and when you press and hold a button so you can change the values, the numbers are not aligned with the semi-transpartent gray background/buttons. But this is NOT the case for the "windows down, Loud" button, things are ligned up. It is only the case when you change any of the values for the other 5 presets.
    EDIT:
    I added this to the Bug Tracker on your website.
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
  3. #2063
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by JohnWPB View Post
    I do not know what could be causing that.... sorry. You do say that RR and the skin work fine if you unplug the USB GPS puck. This definitely is not a coding error then in the skin.... Hmmm
    Try looking in your rr.ini, and in the skin.ini and find a line, if its in there localcaptureinterval and change it to 0
    Then look in the RR Root folder for zips.dll, and if there delete it.
    These are the only two things that I know of that are timed... The skin itself does not have any recurring timers.
    I think i had this same problem but at 60 secs. try and delete the Zips.DAT file. Pretty sure that's what fixed it for me. Its been awhile so I'm not 100%.
  4. #2064
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by TimmyM View Post
    I did have that problem before, too.
    The exact fix for me was to keep the "zips.dat" and remove the "ziplocator.dll"
    This solves most people's problems
  5. #2065
    Jan 2007
    San Francisco
    So. Setting localdatacaptureinterval in rr.ini to 0 fixed this problem. I did try to delete ziplocator.dll and zips.dat before and that didn't help. Thank you John! I'm back now!
    Must be some odd bug in RR then?
  6. #2066
    Sep 2007
    Dallas,TX
    Quote Originally Posted by boriman View Post
    the data capture interval sets the duration in minutes between location queries to fill in the City/County/State, etc blanks used in DFX. The zips.dat file contains the database so deleting that shouldn't really fix anything (unless you were somehow querying a bad entry??). Deleting the dll solves a lot of problems because it doesn't work on a lot of machines (and by deleting it, the system will be able to query without it).
    setting the capture interval to 0 disables it altogether i guess? i would be curious.. however if you deleted your dat file, you won't be getting anything anyways :-p
    glad you got it working
    edit: out of mere curiosity.. do you currently have RR set to read GPS info (i.e. an Xport setup) ?
  7. #2067
    Jan 2008
    Hi there,
    First off, hats off to all those that are involved in the development of this skin, it is truly AWESOME!!!
    Maybe a daft question, but how do you get the visualization working on the main menu screen?
    Any help is much appreciated.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Two words...
    HELP FILE!
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #2069
    Jan 2008
    Fair enough, I have used the help file to get the visualization running in the music screen which works perfectly, but at the bottom the help file says and I quote "You can also use the Visualization on the Main Menu screen. Check HERE to see how", however there is absolutely no link to anywhere.
  10. #2070
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by trydon View Post
    Yikes, that was a part of the help file that I had not finished... I has been corrected for the next release. In the mean time, This is from the addition to the help file:
    Depending on the layout you have chosen for the center of the main menu, most of them have a hidden button at the top, and the bottom of the center square.
    Pressing the top, turns on and off the visual, while pressing the bottom cycles through the plugins.
    My Fiero Build Thread
  1. Help! Need RR and DFX 4.0 advice
    By schwazche in forum Road Runner
    Last Post: 10-15-2008, 02:25 PM
  2. ProScan 4.0 Released
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-26-2008, 11:46 PM
  3. Digimoto 4.0 available for download
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2005, 04:36 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
